Unique Number Sign
2,908
42
6
Introduction: Unique Number Sign
About: DIY crazy always trying new things to make my house a home.
I made this by following instructions from PeterP_DIY.
Thanks Peter
Step 1: Template
Make a template using cardboard or if your feeling confident draw straight onto check paper. I used one of my son's old maths book.
Step 2: Use Exterior Wood
Cut your exterior wood to size and paint with exterior paint. Leave to dry for at least 1 day.
Step 3: Test Run
I did a test run on scrap wood to make sure the holes were not too close together. It actually took me 3 tests to get it right.
Step 4: Time to Drill
Place the check paper on top of the wood and drill your holes through the paper.
Step 5: Final Step
Remove the paper and drill the screws into the ready made holes. I finished off by using a screw driver as suggested by PeterP_DIY who I got this wonderful idea from. When you use the screw driver instead of the drill you can get them nice and level.
Step 6: Enjoy
Hang in your desired position outside and impress your neighbours.
Be the First to Share
    • Candy Speed Challenge
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    6 Discussions
    hohum
    hohum
    4 years ago
    I truly like your idea using screws to make numbers, I'd like to suggest you
    look at an art form called pointillism,
    By using different size screw heads, and nails with different heads,
    you could do this art form. The different screw heads would
    would/could give your art a new range of depth. As the way the light would
    catch the different screw heads.
    Anyway, I really like what you’ve done using screws to make your numbers.
    Jack g
    What I am working on is anamorphic optical
    illusion,
    SORRY the images didn't show up
    Heavenlea5
    Heavenlea5
    Reply 4 years ago
    Thanks Jack, sounds interesting, I'll look into it.
    hohum
    hohum
    4 years ago
    great idea, you might consider varying the depth which create a wave effect,
    Heavenlea5
    Heavenlea5
    Reply 4 years ago
    That sounds great would look really good if you have more numbers as well.
    DIY Hacks and How Tos
    This is really cool. And you can make any kind of sign that you want. All you need is screws.
    Heavenlea5
    Heavenlea5
    Reply 4 years ago
    Thank you, that's true any design would look really cool.
