Introduction: Unisex Dead Coffin Pendant
This is a spooky Unisex Dead Coffin Pendant that can be wear to have a scary fashion or in the Halloween season. This is very light weight, beautiful and terrifying piece of jewelry.
It's a bit of a messy project, but cheap and simple. Just follow the easy steps and make one for your own. The Pendant is mainly made out of Ice-cream sticks, old Chain and Earring stuffs.
The required Tools & Materials that I used in this project are as follows,
TOOLS
- Mini hacksaw
- Plier
- Nipper
- Pen cutter
- Ruler
- Pen / pencil
- Soldering iron
- Dremel
- Sandpaper
MATERIALS
- Ice-cream sticks
- Wood-glue
- Super-glue
- Paper tape
- Aluminium wire
- Color & Brushes
- Foam tape
- Jump ring
- Chain
- Tooth pick
Step 1: Preparing the Coffin Box
I made this Coffin box using regular Ice-cream sticks. Here I cut the sticks very thin to give better real look. Then glued the sticks together and then cut them according to the all Coffin side, up and down shape.
Step 2: Making the Coffin Box
Next, I used some Foam tape on all the sides to easily attach the box side walls. Also I applied good glue on the edges and support them using paper tape.
Step 3: Making Coffin Box Cover
Step 4: Adding Side Batens
Next, I cut some small stick pieces and glued onto the top and side of the Coffin box.
Also a Cross to the top of the cover.
Step 5: Making the Lock
To add some extra details in the Coffin box, I made a small Lock to wrapped around the Coffin box with the help of a chain.
Step 6: Coloring
Then I colored the Coffin box and the Lock in dark fantasy color and let it dry.
Step 7: Adding Chain and Lock
To add the small Lock, I used an old Chain and wrapped around the Coffin box. Then colored them in dark to match the theme.
Step 8: Making the Hook
Here, I made a custom Hook with aluminium wire to fit in the Coffin box so that the Chain can be inserted through it.
Next I attached the Jump-ring to it.
Step 9: Installing the Hook
Now, I drilled a small hole in the top of the Coffin box and fixed the Hook in it. Then I inserted the Chain through the Jump-ring and tighten too the other end.
And thus our Pendant is now ready.
Step 10: Final Product
Thus, our beautiful miniature Unisex Dead Coffin Pendant is now ready to use. Wear this unique piece of Necklace and get ready for a spooky event or fashion.
Thank you so much for reading this instructable.
Please share your valuable thoughts below.
_
Also, SUBSCRIBE to our YouTube channel "technocraft STUDIO".
_
_____________
GET IN TOUCH
Facebook : https://www.facebook.com/technocraftStudioPage/
Instagram : https://www.instagram.com/technocraftstudio/
YouTube : https://www.youtube.com/c/technocraftStudio
Website : https://debojitpaul.in/technocraftstudio/
E-Mail : technocraft43@gmail.com
Runner Up in the
Jewelry Contest
