Universal Locked Door Opener. (does Not Work on Deadbolts.)
292,758
163
51
Introduction: Universal Locked Door Opener. (does Not Work on Deadbolts.)
About: I love the idea of breaking into places. i like anything that is well thought out and things that are very clever. i like to plan things out extensively and to be a step ahead of everyone.
I thought of this brilliant device today when my sister locked me and my friend in a storage room.
My friend lives in an apartment and has an underground corridor running through the storage rooms of the houses. We rigged the door from his room to the storage room so we could get in if it was locked. But we didn't think about rigging the door from the storage room to the corridor. So i thought of a few ways we could open the door and this was the simplest one.
I added a video because no one can figure this thing out apparently.
Step 1: Stuff You Need.
Things you need:
1-laminate card(gift cards work best. I used an itunes card.)
2-scissors
3-a locked door that needs getting into
Step 2: Cut the Card.
take your laminate card and cut a piece out of it that is shaped like this.
Step 3: Unlock the Door
stick the card into the door above where the sloped lock thing would be at. slide it down and over the sloped piece. push the card forward so the sloped thing is pushed back into the door. then just push the door open.
(hint: if the door opens away from you, you are probably going to have to push the card. if the door opens toward you, chances are you are going to have to pull the card. unless some idiot put the door knob on backwards.)
Be the First to Share
    • For the Home Contest
    • Big and Small Contest
    • Game Design: Student Design Challenge
    51 Comments
    JohnD238
    JohnD238
    7 years ago
    You didn't need to cut the card you slide it in to try and find the lock hit the lock sideways a few time then push on the sentence of the spring lock /slope thing that keeps the door locked then the door should pop open
    gwade1217
    gwade1217
    Reply 9 months ago
    The reason for cutting the card are for the doors with the latch bolt facing the opposite direction, so you’d have to have the lock pick device (credit card) on the other side of the match, and you’d have to pull the card toward you rather than sliding it forward like you’d normally do.
    ThomasC206
    ThomasC206
    6 years ago
    Man, thanks a lot...being trying for the past 2 hours, your solution worked in 5 mintues
    JacobS164
    JacobS164
    Reply 6 years ago
    thomas do you have any dimensions of your card or can you be pretty liberal with your cuts?
    ThomasC206
    ThomasC206
    Reply 6 years ago
    It was an expired credit card ;)
    I guess it could be somewhat bigger or smaller but not a lot...
    JacobS164
    JacobS164
    6 years ago
    Does anyone have dimensions on this card? Don't have a lot of time to play with, and want to get it right the first time.
    UrielO1
    UrielO1
    7 years ago
    Thanks Man!! I'll keep a card in my wallet just in case I lock myself out of my dorm room again.
    ZombehhLove
    ZombehhLove
    7 years ago
    I tried it myself because I needed to unlock a door for my friend who got locked out. The door had an outside molding which made it hard, but I cut it out just like he did, and kept measuring it to another similar doors lock. Once I got it to right size I slipped it through. At first I was afraid of breaking the card by pushing the card in too harshly but then once I finally shoved it in at full force the door popped open. 10/10 would def do it again!
    JohnD238
    JohnD238
    Reply 7 years ago
    You didn't have to cut the card it would have done the same if you left the card alone :^)
    kraverbaby
    kraverbaby
    11 years ago on Step 3
    Just tried this on our front door, totally didn't work. When i slipped the card through, it just hit wood, then i tried to wriggle it around the wood to drag down to the lock, but it wouldnt bend around it... :( lol ah well :(
    esecco_20
    esecco_20
    Reply 7 years ago
    this happened to me too
    TiffanyA3
    TiffanyA3
    7 years ago on Introduction
    my 4 year old son seemed to have locked the bathroom door after he walked out. I found this page...cut up the card and pop, the door opened like a charm! thanks!!
    MarkM23
    MarkM23
    8 years ago on Introduction
    Hello! I needed a help with one old door lock. I searched in the internet how can I change the lock alone and I found some tips. I collected it here - http://safekey1stllc.com/7-things-that-you-need-to-know-about-door-locks/. Your article for "Universal Locked Door Opener" is one of my best choices. Thank you for this tips.
    1995duncan1995
    1995duncan1995
    12 years ago on Step 3
    looks like my old high school id is going into good use
    the potato
    the potato
    Reply 10 years ago on Step 3
    well it look like my oldd collection of expired gift cards will go to use
    UnderManiac
    UnderManiac
    11 years ago on Introduction
    Looking at all the doors that lock in my house, I found that there is a pin next to the striker that prevents it from being opened in this manner when the door is closed. The pin is a safety device to prevent this sort of entry method. When the pin is depressed, either using a finger or with the striker plate, the striker can not be pushed into the door housing. This is an old "credit card technique" used ages ago and lock manufacturers make locks that can't be opened using this method.
