Introduction: Upcycle Aquarium Stand or Coffee Table
Step 1: Materials Needed
Tools
- handsaw or miter saw
- corded drill
- power sander
- Dremel (optional)
- Prybar
- Hammer
Materials
- (6) 2x6 measured to 19''
- (4) 4x4 measured to 14.5"
- (1) 2x4 measured to 33"
- (1) 2x4 measured to 25"
- a bag of 3" deck screws
- (2) 2x6 measured to 15"
The cost of this project was around 4$ for the deck screws all the wood was free.
Step 2: Remove Hardware
With the help of my trusty kitty Odie remove all nails and hardware it helps to use a prybar and lots of patience. Discard any wood with signes of water damage or rot in some cases you can can just cut the rotten parts off.
Step 3: Assembly
Once all youre pieces are cut, lign up all youre 19" 2x6 planks face down and screw youre 2x4 pieces to the bottom. making sure you put the scews through the 2x4 to give a nicer finish. Now you can start the fun task of sanding!!!
Step 4: Sanding
Sand everything!! and when you think youre done sanding, sand some more because after years of abuse as a deck you want a nice finish. i started with a 60 coarse sandpaper all the way to 150 fine.
Step 5: Attaching the Legs
Now you attach the legs. I set mine back a few inches so they would cary the load right under the fishtank better. i also added a base to the legs for more stability and height. Now you can finish sanding and add some design if you want.
Step 6: Dremel (optional)
I decided to add some design using my dremel i carved some fish and a sea turtle using my burr bit and sanding bit. you could carve youre name of other pictures.
Step 7: Done!!
now you are done! as you can tell i didnt finish sanding but i ran out of sandpaper i havent decided if im going to stain it or paint it yet more pics when im done. you can go to Wal-mart and get two small storage boxes or one big one that fit perfectly underneith for youre fish supplies or other stuff.
5 Comments
10 years ago on Introduction
Impressive carving. Not sure I would sand decking indoors as it probably been treated for exterior work with some sort of insecticidal and Fungicidal preservative.
We asked its just untreated wood and the shop vac was runnin most of the time
actually its a cat stand x3
we call it cat TV thats why we got the fish in the first place
