Upgrading an Oil Air Separator!
Intro: Upgrading an Oil Air Separator!
I just received my oil air separator from Amazon.com! For 36usd it's a good price however it is just an empty can with no internal baffling to force oil droplets to condense!
Read on for how I fixed it!
STEP 1: Opening and Inspecting!
Using an Allen key I removed the 6 screws. The top has 2 ports so close together that intake will quickly be sucked into the outlet!
The gasket on the cover is very minimal. The bottom of the can has a drain hole. There is a level sight along the outside.
STEP 2: Extending the Intake.
I wanted the blow by gases to reach the bottom of the can. I used a spare length of copper tubing to achieve this.
STEP 3: Baffling.
Using a piece of sponge I slipped in over the copper tubing. This sponge will force the oil droplets to condense.
STEP 4: Reassembly!
I left the sponge near the top so the bottom of the can will collect the oil. I marked which was in and out on the ports.
STEP 5: Drain Valve.
The kit came with a drain bolt but I want an easier means to release the trapped oil. With a nipple, washer and spare ball valve I made the drain valve!
STEP 6: Completion!
There it is. My upgraded oil air separator. Took me only half an hour. My next instructable will be it's installation! Stay tuned!
3 Comments
TerenceG7 3 years ago
BrianC453 6 years ago
Please let us know how the sponge material holds up. I did something similar with a metal scrubby thing...it started breaking down... ditched that and ended up with a series of staggered metal discs.
Mjtrinihobby 6 years ago
So far the sponge is holding up great. The separator is trapping the oil as intended.
