Uploading Sketch to Arduino Pro Mini Using Arduino UNO
Intro: Uploading Sketch to Arduino Pro Mini Using Arduino UNO
I have started my way with the arduino UNO, moving to pro mini I didn't buy the USB adapter but used the UNO board to upload my sketches.
STEP 1: Removing the Atmel IC
Very cerfuly remove the Atmel IC from the Arduino UNO, the pins are very gentel so be very cerful.
I used a flat driver, twisting it gently from both sides to take it out slowly bit by bit.
STEP 2: Connection
Connect UNO's pin 5v to mini's main VCC pin,
UNO's pin GND to mini's main GND,
UNO's pin RX to mini's RXI,
UNO's pin TX to mini's TX0,
UNO's RESET to mini's GRN
STEP 3: Load Sketch
Load the sketch to the Arduino IDE, for the example I used the Blink sketch wich is also used for an Arduino first test
STEP 4: Set Board
Set the IDE for using the pro mini board,
Tools => Board => Arduino Pro or Pro Mini (5V, 16Mhz) w/ Atmega 328
STEP 5: Upload Sketch
Upload the sketch using the regular uploading button.
STEP 6: Your Good to Go
You should recive the "Uploading Done" massage in the status bar and you are good to go, sketch uploaded.
Now go make something...
39 Comments
goldenshuttle 7 years ago
arduino pro mini has a factory problem..i tried many of them do not take code, not from USB converter like PL2303 or any other ..also not from another Arduino...probably this model has a fundemental problems..i do not advice anyone to buy or use arduino mini..it is just a big waste of time
Gaura_Chethana 5 years ago
FeketeP 5 years ago
Regards Mpu 6050 + arduino mini pro +mp3 WTV020M01 v1.00 interconnection ask for help
KaranD16 8 years ago
A slightly different configuration worked for me:
Pro Mini ----- Uno
DTR -------- Reset
VCC ------- 5V
GND -------GND
RX -------RX
TX------------TX
sproarash 6 years ago
Thank you very much. it worked for me.
AlexS616 7 years ago
I realize this is old but I tried this method and it worked properly.
sarwdaenj 6 years ago
in arduino IDE tools->programmer->?? what we have to select.
HarrietWilson 7 years ago
Hello!
I have an Arduino mini pro (a replica version). It was working fine, and uploading code fine. I dont think i changed anything. However now i am having the following issue:
- COM port coming up
- upload error: stk500_getsync() error.
I have other Arduino pro mini's in same set up that are working just fine so i dont think it has anything to do with the computer (drivers ect..) or the FTDI port.. It must be to do with the board.
Do you have any ideas? Its possible its the bootloader but that seems like such a rare issue that I would like to try other solutions first!
Any help will be gratefully received! I have collected data for my final project using this sensor and i didnt get to calibrate the sensor!
Thanks in advance!
Harriet
StefanS96 7 years ago
Thanks, very helpful!
SelvamaniR 7 years ago
hai friends i am using arduino pro mini board .and i can connect the board to usb using the cable named as(TTL to USB converter PL2303) but it can't connect the board so i cannot able to send my program in this board what can i do.......?help me for this problem the error like avr
dude ...
udubinsky 7 years ago
Can you provide with more details ?
Your connections, the complete error massage, etc.
onion2 7 years ago
PRADEEP KUMARS 7 years ago
Thanks for your instruction.Its working properly.
KailashT 8 years ago
when communication between pro mini and uno which programmer mode is select...
i made connection like given image but is not running what should i do.. and there is any other driver installed for pro mini...
zecojim 8 years ago
does this work with arduino pro mini 3.3v.?
udubinsky 8 years ago
zecojim 8 years ago
is it okay if i use a voltage divider.?
namindu 8 years ago
thanks it's working
RGK2015 8 years ago
AdjiR 8 years ago
Dear Sir,
I have a new one arduino UNO,
How to setup proximity sensor 10 V to 30 VDC (omron SO8KS02) to collected Odometer (speed and Dintance)
please reply
