Upside-down Glasses
Intro: Upside-down Glasses
Here's a quick simple pattern for making glasses that turn your vision upside down. Although this could be cut by hand, it'd be nearly impossible. All of this was designed for the Instructables laser cutter. The only things you need for materials are 4-40 machine screws, standard washers, and 4-40 nuts, four of each. You'll also need a piece of mirrored plexiglass.
STEP 1: Download and Laserize
If you just want to get yourself a pair of perspective flipping goggles, all you have to do is download the file, arrange the parts to be cut (being sure to include two earpieces, they're identical, you know) and laser cut yourself a pair (mirror side down on the plastic, please.) It's pretty simple.
What those of you without laser cutters (poor souls that you are) may take away is this cool construction method I learned from puzzle maker Lee Krasnow. I measured my screws, nuts, and washers, and modeled them simply in cad. I measured the width of my plexiglass. Knowing those dimensions, I could make some tabs in the design. When the design is put together, the tabs keep the different panels aligned and square to one another. the screws fit down through the holes, and connect with the nuts in the adjacent panel. The nuts are held fixed by their tight fitting in the plastic. Putting these together is a breeze, really.
STEP 2: See?
These are just a fancy version of holding a mirror underneath your eyes and looking down into it. The effect is pretty cool, but the design could use a little more tweaking to be perfect.
I went through a lot of revisions in the design, testing and prototyping the model before reaching a final product. The laser cutter made it easy to test new revisions on the spot.
STEP 3: Cool.
Nes pas?
28 Comments
patriots8888 12 years ago
ɟo ǝuo ʇuɐʍ ı ¡ןooɔ
DeveloperL 7 years ago
Hello,
that text you made was incorrect.
This does not rotate 180° on the Z axis. Instead, it would invert
your Y scale from 1 to -1.
This being said, you would have to have the text in correct order, but upside down.
(For example: '¡ןooɔ' would be 'cool¡')
DmitriyHoh 10 years ago
Nice job but a lot of extra light into your eyes and very
small field of view.
Among scientists this device is named invertoscope.
Upside Down Exclamation Point 10 years ago
Adum24 12 years ago
Cyberscann54 12 years ago
Cr4zy_Dud3_0n_F1r3 12 years ago
HisDivineShadow 14 years ago
it ticks me off...
old_bass_masta 16 years ago
duck-lemon 16 years ago
Meie 15 years ago
bujo0 15 years ago
old_bass_masta 15 years ago
Meie 15 years ago
http://www.youtube.com/watch?v=XdXgoLezKnc
(btw, after some research, i found out its waaaay better to use some prisms from binoculars, much more sight and you don;t have to look down)
T3h_Muffinator 16 years ago
prank 16 years ago
nagutron 16 years ago
Bubjo 16 years ago
