Urban Homestead Garden (squarefoot Gardening Abridged)
Intro: Urban Homestead Garden (squarefoot Gardening Abridged)
We're turning the concrete jungle backyard of our townhome into an experiment in sustainable urban homesteading. Here's how you can add some OCD (i.e. easy to maintain) gardening space using an adaption on Mel Bartholomew's Square Foot Gardening practices (build up, don't dig down and organize in sq. ft.).
http://www.squarefootgardening.com
Super easy, lots of fun.
- NOTE!!!! Before anyone comments about pressure treated lumber...READ THE INSTRUCTABLE, we already advise against it in there and just because the wood LOOKS like treated lumber to you, doesn't mean it is. It's poplar. Poplar and a non-white balanced cheapo camera!!! Leave it alone or offer to buy me a better one. And YES, I totally abuse my kids. We've already dealt with THAT too in the comments...so if your comment isn't about the topic at hand or not a question, with all due respect....keep it to yourself. Thx.
STEP 1: Planning and Materials
Bartholomew's plans call for 4'x4' boxes with space for walkways around the edges. This makes the perfect size to reach the garden from all sides. Not having the luxury for space, we cut this down to 2'x4' boxes since we wouldn't be able to access the back of the box. So adjust your materials accordingly if you go full size.
MATERIALS we needed for 2 2'x4' boxes:
- 3 pieces of 1"x6"x10' lumber*
- screws (we used 2" decking since we had some laying around)
- covering for the bottom (we used old window screen, but plastic, fabric, plywood would work too)
- industrial screws
- String
- compost, newspaper, potting soil of choice (See Bartholomew's site @ http://www.squarefootgardening.com for his super mixture. This should probably vary depending on what you will be growing though.)
- Plants and/or seeds
TOOLS
- Saw (we used a jigsaw since we are masochistic...I mean live in a townhouse and don't have the room for a table saw)
- Industrial Stapler
- Electric Screw Driver
- industrial screws
- String
TOOLS
- bonus for reclaimed lumber, but sadly since the building slump hit our area pretty hard and we haven't had any hurricanes (knock on wood) recently, recycled/reclaimed lumber is hard to come by. Use poplar if you can afford it, some plants dislike pine and pressure treated could release chemicals into the soil (or so I heard).
STEP 2: Playing With Wood
You'll need to cut your wood. We had lots of innuendo in this project, it started here with the getting of the...well, you get it. We needed two 2' cuts and two 4' cuts per box. Plus we were making 1'x1' extenders to grow potatoes in.
The theory is, start the potato plant on the same level as all the other plants and as the sprouts break the dirt level, keep adding more dirt in the extended. So instead of only having 6" of growing room, an additional extender increases the space by 6" and with two additional, we'll have 18" of dirt for the potatoes to grow through.
So in total we had two 2'x4' garden boxes and 4 1'x1' extenders, for a total of the following cuts of wood:
Four 2' pieces
Four 4' pieces
16 1' pieces
Four 2' pieces
Four 4' pieces
16 1' pieces
STEP 3: Screw It
Put your pieces together with..screws! 3 in the sides of the main boxes and two each in the sides of the extenders. Bartholomew suggests alternating which ends meet at each side so you have a consistent 2'x4' interior
STEP 4: Staple Your Screening
Staple your screening (or plastic, materials or whatever you are using (use small nails if using plywood)) along the bottom edges of your main boxes to hold in the dirt.
STEP 5: Fill 'er Up
With newspaper, compost, leaves, and other organics. See the great composting instructables for more.
STEP 6: Gettin' Dirty
Dump in your potting soil (or special mix of your liking) and spread around.
STEP 7: Measuring
Mark off 1' increments along the edges of the garden. You'll be using these to lay out your squarefeet pods.
STEP 8: Create a Grid
Staple your string or nail your recycled wood (Bartholomew suggests recycled venetian blinds) along the marks you just made to make a grid.
STEP 9: Planting and Maintaining
Now that you have 1' sections, you can get to planting.
Plant according to your plant's directions, for example if you are suppose to plant every 12" apart, place1 plant in each area, 6" apart = 4 plants/area, etc.
Comparing 4 plants in a 1' square area compared to 36" needed for row gardens plus the space for walking between the rows...this method seems to be a great idea for gardening, plus if you ad a plywood bottom and legs, you can bring the planters up to wheelchair height.
129 Comments
Chard 15 years ago
DIY-Guy 10 years ago
Crush macadamia nut shells or hazelnut shells (also called filberts) last a long time and deter the tenderfooted slugs and other varmits. Some orchard managers are surrounding the bases of their trees with these nut shells once a year and enhancing the soil via slow composting. A two-for-one effect.
Solderguy 15 years ago
Lumber yards label the treated wood with the names of the chemicals. Mercury is not allowed by default in many countries. Not a big concern for a thinking person. Have a nice day!
wildfyre 14 years ago
neigerg 14 years ago
Again, thank you for the instructable!
Self-watering in a small space can be done with filled water bottles turned upside down with the neck buried into the soil. Place caps with a tiny hole on them if you feel it's watering too fast. Place bottles between plants in the middle of the grid lines where the lines cross over. Watch for bottles that do not drain and check for soil blocking the drain opening.
alochin 15 years ago
saintneko 15 years ago
http://en.wikipedia.org/wiki/Humanure
Right, infection is a consideration. But a large quantity of heat or time will take care of that. Some people just make a big pile and when they dump it for composting and aging they wait a year from the time they dump it in to a pile. Plant a dated stake in the pile and it's easy to know when it's ready.
shellberry 15 years ago
I've read that human urine is great for nitrogen and I threaten my plants I will pee on them if they misbehave :)... the idea of an S/M relationship with my plants is...delightfully intriguing and warrants a blog.
I've also read that you can use the crystals from disposable diapers in the gardendisposable diapers in the garden as well... and I have my eye on an enviroletenvirolet..maybe for christmas! Nothing says "yay! birth of jesus!" like a toilet?
fuzvulf 15 years ago
We use it to control leaf curl on our cherry and apple trees. But even more important are the fungal infected leaves at the base of the trees. Get rid of them, burn them! Ants climb through the fungus and carry it up to the treetop leaves when they are farming aphids. One thing that helps stop ants from wanting to climb the trees is to put a sticky ring around the trunk. Double sided carpet tape works ok and eventually falls off but looks like trash on the ground. Another option which we have not tried is to paint sticky stuff on the trunk. We avoided that method just in case the bark might become damaged in a full ring around the tree.
I came across a reference for 20/1 dilution (water/urine) for a nitrogen feed every two weeks. That also allows the smell to die down in between. Apologies for not having the link to the reference. I can say though that it works in our garden, and we stop when fruit appears after the bloom stage.
James (pseudo-geek) 15 years ago
knektek 14 years ago
hcold 15 years ago
neigerg 15 years ago
