Introduction: Use Soap
Use Soap is a machine that will remind you to use soap. When some kids enter the bathroom, the machine will beep ,but if you open the box to get soap, the ring would stop.
Here I will tell you how to make this"Use Soap"
1.I started the machine with Arduino; I add the ring and the Ultrasound.
2.I used card board and made a box with the top able to open.
3.Cut a hole in the front so that you can put the Ultrasound in.And also add the Light sensor in the box, to check if the box is open.
4.Add a old plastic bag in the box, so that your box wont get wet.Put the soap on the bag.
5. Remember to use soap to wash your hand !!!!
published and write by Gemini Chen (陳泓廷 from Taiwan)
Use Soap是一台會提醒您使用肥皂的機器。 當有人進入浴室時,機器會發出蜂鳴聲,但是如果您打開盒子拿肥皂,鈴聲就會停止。
在這裡,我將告訴您如何製作“肥皂機”
1,我用Arduino啟動了機器; 我添加了蜂鳴器和超音波。
2.我用卡紙板製作了一個可以打開頂部的盒子。
3.在盒子前面挖洞,把超音波黏上.
4.在盒子裡放一個舊的塑料袋,以免盒子弄濕。
5.記住要用肥皂洗手!
陳泓廷(Gemini Chen "台灣")出版和撰寫
Step 1: Arduino
Step 2: Ultrasound
2.I cut a hole in the front to put the Ultrasound in.
2.在盒子前面挖洞,把超音波黏上.
Step 3: THE BOX
3.I used card board and made a box with the top able to open
3.在盒子前面挖洞,把超音波黏上.
Step 4: Done
Done, you can put this in the bathroom.
3 years ago
Thanks for sharing :)
