Strip Wires the Easy Way!
Intro: Strip Wires the Easy Way!
When I was making my pressure plate, my wire stripper decided to disappear..that's when I discovered this laughably easy technique for stripping wires. It's so easy, that I can't believe that I haven't seen it before. The scissors on my leatherman were perfect for this job, because they could cut through the plastic coating on the wire, but not the metal itself. This same method will work with normal scissors to, as long as you don't use all your strength when cutting.
STEP 1: Cut!
Simply act as if you were going to cut the wire in two...but don't. Stop adding pressure when you reach the wire, and spin the wire around. You want the blades of your scissors to have touched the wire all the way around. When you're done with that, the plastic will just be indented all the way around. Next, give it a few bends...the plastic will easily split, revealing the metal.
STEP 2: Finish Up
Once the wire is exposed all the way around, you can just pull the plastic off with your fingers. If you cut too far in, you may have to use pliers (or teeth, in a pinch) to get it off, but fear not, it will come off quite easily with such implements. Automatic wire strippers are favorable to this, but if they decide to disappear on you, like they did to me, you'll be OK now that you know this little trick!
24 Comments
Jackass_Of_All_Trades 5 years ago
By cutting laterally without a protected blade you sever, score, and flatten many of the outer strands so they either have resistance /heat/fire issues immediately or crack and separate and become a fire hazard later
Handsome-Ryan 16 years ago
HaremCinema 6 years ago
Good points. As a full time handyman I used this technique (most often I used a knife) and it works well. Practice helps and some smaller wires are harder to do, obviously. Nice tip.
fifty_ohms 9 years ago
I tried this after I read this instructable. It worked great. Nice 'ible! Thank you very much.
tobywinks 9 years ago
zachninme 16 years ago
KalElonredkryptonite 10 years ago
Yeah, except wire strippers are precise and won't nick or damage the wire.
Weissensteinburg 16 years ago
t34r 11 years ago
This lighter technique can be used without even cutting the plastic sheath, just heat where you want the final length the most then quickly run the flame along the sheath to be removed whilst rotating the wire, pinch the wire sheath and pull. I suppose you could use pliers if your fingers are sensitive, though your fingers will toughen up after the first day of using this method.
mrxavia 15 years ago
killerpoopguy 11 years ago
nutsandbolts_64 14 years ago
Colonel88 14 years ago
Mother Natures Son 15 years ago
Ubergeek85 16 years ago
T-K 15 years ago
benthekahn 15 years ago
T-K 15 years ago
struckbyanarrow 15 years ago
LinuxH4x0r 16 years ago
