Use Your Canon EOS 1000D As Webcam! *UPDATED*
Intro: Use Your Canon EOS 1000D As Webcam! *UPDATED*
Hi,
in this tutorial I'll show you how to use your Canon 1000D (the others would work, too, but I couldn't test any other) as a webcam without any hardware/software hacks, just software solutions ;-).
Sorry my English, if you find mistakes please notify me.
You'll need this stuff to use it as a webcam:
- Mini USB cable
- a PC ( I don't know how to do this on Macintosh) *EDIT* : Liveview works on OSX 10.5.2 but I don't know a program for the screen capture, yet........ ;-)
- EOS Utility (not downloadable, you should get it from the EOS Solutions Disk that is usually bundled with your camera.
-Free OpenSource alternative http://sourceforge.net/projects/eos-movrec/
Supports even AF !!!
A little video:
- Mini USB cable
A little video:
STEP 1: Getting Started
Take your Canon EOS 1000D and open the cover on the left side.
Get your usb cable and plug it into the camera and into the PC.
You should have EOS Utility installed, now turn the camera on.
Start the application EOS Utility and choose Camera Settings/Remote Shooting (don't worry why mine is so called, it's German).
After you've chosen the third option a new window appears. Click on the third radio button at the bottom.
Again a new window appears that'll show you what the camera sees, change the lens to manual focus and adjust the focus till you see everthing sharp in LiveView.
Now you can see what your camera sees on your computer screen but you still can't use it as webcam. The next step will show you how to do this.
STEP 2: Creating the Webcam
Download the VH Screen Capture Driver here: http://www.hmelyoff.com/index.php?section=9
It's free and a useful software solution. After you downloaded it install it.
You can find it now in your startmenu, look at the picture and start the config.
Click on "Create a new one".
Now place your LiveView windows in a good positon where it doesn't annoy you, if you have another monitor place it there(I placed it onto my PSP, tuts are aviable somewhere else). Press the button that's named Region in the lower middle on the window from configuration of VH Screen Capture Driver.
With this tool you select the area of Live View that shows what the camera sees. Close the config and you're done ;-).
Get your messenger on and do some video chat :-)
Have fun.
If you have any questions you can send me a PM or make a comment.
Mine :-P:
Have fun.
Mine :-P:
35 Comments
BenoSpeedwagon 3 years ago
EOS Utility 3.10.30 for WindowsLast Updated :02-Aug-2019
Dwargh 4 years ago
You don't actually need the provided CD to get the EOS Utility installed ;)
The installer is just looking for a certain registry entry.
Create 2 text files.
Name the first "EOSx86.reg", the second "EOSx64.reg".
Edit "EOSx86.reg" with notepad, insert the following text between the dashes (not the dashes themselves!):
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Canon]
[HKEY_LOCAL_MACHINE\SOFTWARE\Canon\EOS Utility]
Save the file, execute it. Let it make a new registry entry.
Edit "EOSx64.reg" with notepad, insert the following text between the dashes (not the dashes themselves!):
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\EOS Utility]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\DPP]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\ZoomBrowser EX]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\ZoomBrowser EX\Settings]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\ZoomBrowser EX\Install]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\PhotoStitch]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\EOS Capture]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\EOSViewerUtility]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\ODSK]
Execute the Canon "updater" euw2.14.20a-updater.exe, it should work now.
DuncanR14 5 years ago
This link is 404'd now.
anuragsrathor 9 years ago
I am using the EOS Utility and a USB cable, but I am unable to select the "Camera Settings/Remote Shooting" option on the utility app. Any help would be highly appreciated. Thanks!
ned103 7 years ago
I realize your message is 2 years old, but, I ran into that problem too in the past, and again today. You need to upgrade your EOS Utility software. I upgraded to EOS Utility 2, and the problem went away. I was able to have full access to my Canon 7D again via my PC.
ned103 7 years ago
On a side note though, it'll same images to you computer but it won't save video feed. That is still saved to the memory card and you have to later upload that to your computer.
Paula Pinto 7 years ago
Hi! With this you can record continuously without time restrictions? Or, as when you record directly to the camera, you can only record for 30 minutes? Thanks!
xdread 7 years ago
Vielen Dank
BrunoA7 8 years ago
Worked for 500D
SyedZ2 9 years ago
Worked for my 650D
A word for those who couldn't succeed... first make sure you have all the drivers installed.
DéboraM1 9 years ago
I tried everything you said but whenever I try to use EOS camera movie record it says it doesn't find the camera and that the connection is lost even tho every window is open and the cable is connected.
sparkosoft 11 years ago
mfarooqi 11 years ago
beautiful man!!!!
somsof62 11 years ago
cantidepresivo 12 years ago
Spectrace 15 years ago
sbustos 12 years ago
robleeisgreat 14 years ago
ruleoffire 14 years ago
