Using Swedish FireSteel to Ignite Tinder
Intro: Using Swedish FireSteel to Ignite Tinder
This instructable will introduce the basics of starting a fire by method of Swedish FireSteel. FireSteel easily ignites damp tinder with a spark in excess of 3000 degrees Celsius (5500 degrees Fahrenheit). This method of fire making is also beneficial when on a prolonged outing as a continual source of matches or fluid would not be available.
STEP 1: Get It!
To create a flame we will need only three very basic items:
- fuel (in this case a stick of oak)
- a knife or scraper of some type (this is only needed if you plan to use wood as a fuel)
- Swedish FireSteel
My FireSteel is made by Light My FireLight My Fire. This is the same company which created the original Swedish FireSteel for the Swedish Department of Defense.
- Swedish FireSteel
STEP 2: Shave It!
For tinder we will be making wood shavings. The texture of our shavings will not be quite as fine as sawdust but our intent is to create as "fluffy" a tinder as possible. "Fluffy" tinder traps the oxygen in the air between its particles creating conditions suitable for combustion even if the shavings are from damp wood.
This tinder is procured simply by rubbing the blade of a knife perpendicular to the grain at a 90 degree angle to the surface of the wood. A handful of shavings is more than adequate for making a simple fire.
This is the easiest and most readily available source of tinder, given that you have wood.
STEP 3: Spark It!
Gather the tinder on a dry surface in a mound.
Place the end of the FireSteel at the base of the mound as to help direct the sparks into the tinder. The striker on the lanyard has two unique features. Because the striker is stamped, the edge of the embossed side is rounded (the top), and the back side has a resultant burr (the bottom). As long as the "up" logo is facing towards you, any edge on the striker may be used (the serrated side seems to roughen up the FireSteel). If you do not want to bother with which side of the striker has the burr and you do not mind dulling a blade, the slicing motion of a knife seems to do the trick. If you are experienced, you can get it on the first try ( I have yet to do this). If not give it a few more tries then rearrange your mound or add more tinder to increase your chances.
STEP 4: Ignition!
Congratulations!
I find there is nothing quite as rewarding as making such a primal necessity as fire without aid of lighter or match.
30 Comments
itsruthanitha 8 years ago
Great Strategy, Thanks for sharing the Insight. Recently I bought this Waterproof Firestarter, The ferro rod and which are both included in 1 fire starting kit and that fits conveniently in your pocket. I found this discount code. http://patriotdeal.com/collections/all/products/flint-firestarter Use this code "PD10"and save 10%.
Polaris96 10 years ago
The FireSteel is SUPER useful as long as you take the time the practice with it. I grew up in the woods, but always thought these things were garbage until I started teaching Survival. Here are things I discovered along the way:
1. The striker can be any "hard" object that shaves sparks. It doesn't need to be carbon steel (the Ferro Rod has steel in it, already).
2. The easiest "first timer" material is drier lint or cotton balls. Even if you want to use natural tinder, practice with cotton balls to become comfortable with throwing sparks.
3. Focus on Containing and Directing the sparks from the steel. An easy way to do this is by holding the striker and pulling the FireSteel against the striker. Think of the striker as a mirror which should be reflecting the sparks into your tinder.
4. A good first Natural tinder is an old charred log (it should be dry). place the rod firmly into the center of the charred part and use the back of a knife to scrape sparks down onto the char. This will give you a coal, which you can blow into flame as with flint and steel.
Finally, I don't like magnesium blocks because the weight would be better spent carrying a second Ferro Rod. Magnesium works great but it's really no different than packing a lighter. Instead of the magnesium block, buy a 6pack of bic lighters. They work better for the same price.
jgiegerich 14 years ago
pdlbooboo 13 years ago
NullLifeException 11 years ago
gcollin 13 years ago
strods 14 years ago
http://www.duluthtrading.com/search/searchresults/57001.aspx?feature=product_3&kw=firesteel&processor=content
That being said, I will say that for me it normally takes time. The trade off for a fire started that lasts practically forever is that it is a little slower to start a fire. I think that's why they called it an art form back in the day.
For advice, I would suggest patience, and realize that it will take a bit. My average is 5 to 15 minutes. For tips:
I suggest trying to get something more along the variety of leaves, grass, cotton, pocket lint.
Try to make a bowl or ball of materal to catch the sparks. Watch the tinder closely as as you see smoke and smoldering (which you will likely see first) then start blowing to encourage that to flame.
oldanvilyoungsmith 14 years ago
lord voldamort 14 years ago
Thelonelysandwitch 15 years ago
lackofmotive 15 years ago
bylerfamily 15 years ago
nc527 15 years ago
rorionp 15 years ago
kraM 15 years ago
kraM 15 years ago
chuckr44 16 years ago
