Using Your Laptop As an Xbox 360 Wireless Adapter (Dec 2009) (Vista/XP)
Intro: Using Your Laptop As an Xbox 360 Wireless Adapter (Dec 2009) (Vista/XP)
Intro:
I'm tired of all those other post out there about trying to get your xbox 360 online with your laptop which most tutorials are very complicated or simply don't work or then make your Ethernet adapter incapable of getting internet without undoing the process. I found a better yet simple way and you can still get internet from both Ethernet and Wireless card without undoing this.
NOTE: Does not work with USB EVDO Internet (since they work over dial-up)
STEP 1: You Need:
1)A Laptop with both Wireless and Ethernet Adapter
2)An Xbox 360 (obviously)
3)ANY Ethernet Cable, You can even use the one that came with the Xbox.
STEP 2: What to Do With All These:
Instructions:
1)Go to Network Connections in the Control Panel
2)Select Both "Wireless Network Connection" and "Local Area Connection" .
3)Right Click and select "Bridge Connections"
4)Connect your ethernet cable on the back of the xbox 360 and on the ethernet adapter con the laptop.
STEP 3: Finally!
NOTE: Don't turn on the Xbox 360 if the Network bridge is not connected properly or you'll get an IP error and won't be able to use xboxlive.
Now turn on your Xbox 360 go to Settings and do a Network Test.
It should work if you did all the steps correctly.
Welcome to Xbox Live with your Laptop!!!
by DavilaDarkness
by DavilaDarkness
31 Comments
apeterson9 12 years ago
kujo911 11 years ago
http://forums.hexus.net/networking-broadband/4607-problems-xps-network-bridge.html
techman2005 14 years ago
MarEXksz 13 years ago
kcote 14 years ago
Mr.carface 13 years ago
Paul11125 13 years ago
Little Einstein 14 years ago
Does anyone have a solution?
JuniorRawr 13 years ago
Little Einstein 13 years ago
bubblegum47 13 years ago
midgetarms94 13 years ago
amklsw 14 years ago
i followed you instructions and it works great. except it disconnects or it get interrupted during online game. and the game im playing online freezes. im still testing and observing. it is not something that happens all the time. so dont be scared.
instructions are great if you follow them it should work good.
im using windows 7 and it works fine.
Thank You!!
TheAntiHeroHimself 14 years ago
motorcross 14 years ago
and i takes so long to update/plz reply
modrew 14 years ago
xbox 360 14 years ago
ballistik 14 years ago
