Uv Light Ozonator and Watersterilizer
Introduction: Uv Light Ozonator and Watersterilizer
This instructable will help you to build a ultraviolet light box that can sterilize water, kill bacteria (including yeast) and make ozone.
What you will need:
Screw driver
Aluminum foil
Box
Duct tape
Plug
Wire
Scissors
9watt uv-c light
9watt fluorescent tube ballast
Hot glue gun and glue
Latch
Step 1: Step 1: Prepping the Box
Cut a small hole in the side of the box for your power cable
Then tape up all the inside corners so that you box will be "light tight"
Line the insides of your box with aluminum foil
Step 2: Step 2: Wiring
  1. wire the plug (I ve got a South African plug)
  2. Install a switch
  3. Attach the power cable to the ballast
  4. Run the power cable through the hole in the side of the box
  5. Place the ballast in the box
Step 3: Step: 3 Safety
the reason that the uv-c light is in the box is because IT Is DANGEROUS to look at and may affect your vision if you look at the light for to long!!!!! You will get arc eye if you look at it and it takes up to a week to regain your vision.
Symptoms include:
  1. Irritated eyes
  2. Swelling of tissue around the eyes
  3. Loss of eye sight
  4. Stinging sensation.
  5. Eyes swollen shut.
Step 4: Step 4: Latching Closed
attach the latch to the box's lid and side and
You are Done!!!
Formlabs Contest
Formlabs Contest
Make it Glow!
Make it Glow!
First Time Author Challenge
Be the First to Share
    • Laser Challenge
      Laser Challenge
    • Cookie Speed Challenge
    • Paint Challenge
      Paint Challenge
    8 Comments
    Doctor90250
    Doctor90250
    7 years ago
    what are some common applications for a UV-C source, and can i use UV LEDS? if so, what wavelength, (in nm) is C?
    Brennn10
    Brennn10
    Reply 5 years ago
    200-280nm
    dwhite0
    dwhite0
    6 years ago on Introduction
    Aren't your pictures upside down? How about a wiring diagram. How did you fasten the tube?
    Palframanl
    Palframanl
    7 years ago on Introduction
    all you have to do is add a glass of water and turn it on and it will start to ozonate
    seamster
    seamster
    This looks very interesting! But I'm left wondering how you use this. Can you add some more details?
