V10 (vawt,savonius,vertical Axis,windturbine,ametek)
Intro: V10 (vawt,savonius,vertical Axis,windturbine,ametek)
http://www.vawt.ca Here we go again, building another vawt.
With this one I am hoping to get the 100 watts.
Here is how I did it.
First we need:
--5 pvc tube. size 3"X10' (hardware store)$48
--3 bike wheels. size 12" (junk yard or ask your kid to use their bikes for a minute) maybe $5
--Ametek38 volt (ebay or surplus store) $60 (a problem with ametek, it needs 500 rpm to reach 14.1volt.
--Or buy windblue alternator (ebay) $250 it will only need 200prm to reach 14.1 volt
--1 square foot 1" plywood or anything 12" diameter (laying around)
-- 3 X 2x4 X 12' studs (from lumber store)$11
I am not going to name the tools, but I used the usual tools.
faroun
STEP 1: PVC Pipe
1-I cut the tubes in the middle
2-Using a template, to where I want the hole so the pipe did not travel past the rim, I simply drilled the hole (as shown in the photos)
3-I laid the 1/2 pipes down alternating ends. We all know that the pvc has one end wider than the other to be able to fit to each other (phlange)
That was it for the pvc..really ...that was.
faroun
STEP 2: Bike Rims
It takes 3 to tango on this one.
1-The rims are all the same size 12"
2-I removed the spokes on one side only
3-I left the top Rim as is and used the rim's axel as a bearing
4-I left the middel one as is
5-I drilled the bottom Rim out or cut off the axel cover including one end(shown in photos)
I then placed a piece of plywood on the bottom for support and cover for the generator. To find the centre, you simply use a thread and wind it through the removed spokes, and where they meet you will see a star and in the centre of the star is your mid point.
faroun
STEP 3: The Frame
1- It is a 12' high and 2' wide box.
2-I drilled a hole on the centre bottom of 2x4 for the Ametek back end little shaft to sit in (only an Ametek owner will understand this step)
3-I drilled a centre hole for the top axel to screw in, for the top section.
faroun
STEP 4: PVC Blades Assembly
Before you start you need to know that the spaces between the spokes vary closer to the centre, so use the wider side of the pvc on the more loose separation between the spokes on the wheel, that is why we Alternated the pvc end...remember.
1- Slide all bike Rims in place first
2-Screw the end rims first, one PVC at a time.
3-Once you finish the end Rims, then you screw down the mid one.
faroun
STEP 5: Result and on Going Testing!
After all is good and it is spinning, I realised it can only go to a max of 350RPM before it starts to bulge.
The Ametek requires 500rpm to get 14.1 Volts.
Options are to gear the Ametek or to buy a WindBlue 12 volt alternator, or for me to make a Custom biuld Alternator.
So what Option do you think is the best?..
In total it cost me $125 plus screws and my time. Really cheap.
Regards
faroun
118 Comments
vishnumabeer 7 months ago
fixingthings2 8 years ago
Faroun,
Question....who the heck is 'NORTHER MACJINERY WEB SITE', cannot find it anywhere. Was he talking about Northern Machinery, Or Northern Tools? Or china, perhaps?
kretzlord 15 years ago
electronic spark 12 years ago
jj.inc 13 years ago
faroun 13 years ago
the drum or savonius works on tork and most will not excceed 200rpm.
lift is more effecient, but the rpm causes few issues so it has to be build well.
sam
amorarun 13 years ago
faroun 13 years ago
i cant promise a full instructable, and i am so bussy at this time.
maybe in the future i will create it.
i have about 17 vids on you tube to see the Evolution.
regards
sam chamas
Phred1701 13 years ago
Looking at the photos, I'm thinking that you really cant turn the vanes any more towards the *outside* of the rim because you wouldn't have anything to attach to the rim. The way the vanes are constructed requires the orientation shown. If the builder had left a small ring at either end, that ring could be attached to the rim, allowing the vane to be rotated so that the concave face presents more 'windwardly', but this would make constructing the vanes MUCH more difficult, with little realized difference.
@Faroun:
Have you considered twisting the vanes along their length? As half a pipe, the vanes should have much greater flexibility around their vertical axis. You could rotate the rims w/respect to each other to twist the entire assembly. Would be interesting to see if it had any effect.
I like this design a lot, Nice Job!
faroun 13 years ago
regards sam
macrumpton 14 years ago
I was noticing the other day that wind gets greatly accelerated when it goes around the corner of a building, so I thought this would be the ideal place for mounting one of these turbines. How much vibration do they make? Would it cause structural problems for a building it was mounted on?
faroun 14 years ago
sam
Mcanical 15 years ago
faroun 15 years ago
chouf 15 years ago
faroun 15 years ago
the letter "V" stands for the num,ber of pvc Vanes, v10 has 10 vanes at 3"
V8-4" has 8 Vanes at 4".
the intersting design got the GSD at harvard attention.
http://www.greenenergywindturbine.com/harvard/preview.html
regards
sam
quasar88 15 years ago
Looks like the photos on the link you give actually designed the center bulge in.
I'm seriously thinking about building one but I'll build my own alternator. I have a few links on this if you haven't seen them already.
http://www.windstuffnow.com/main/projects.htm
http://www.otherpower.com/wardalt.html
http://www.otherpower.com/wardmil.html
faroun 15 years ago
Thenwcp 14 years ago
