V8 Vawt,savonius,vertical Axis,windturbine,ametek)
Intro: V8 Vawt,savonius,vertical Axis,windturbine,ametek)
http://www.vawt.ca After making the V10 I realized that off the shelf, cheap dc Motor requires alot of RPM, I do not want to gear something made of so light material that it does not have the mass to sustain the rotation, so I decided to design and build one that has more RPM yet has the same Blade area and that is when I decided to build the V8.
V8 is made from the follwing:
-8 x 3"x10' PVC pipe cut to shape as in rendering($9.89 each)(79.12 total)(vanes)
-2 x 2"X1" permanent caps (sewer pipes aisle)($1.99 each)(brackets)
-1 6" bike axle from an old bike (free or few $)(top axle)
-1 5" long male/female adaptor ($7.99)(bottom connection)
-1 9" hard plastic tricycle wheel (free)(center bracket assembly)
-24 .75"x1/8" screws ($1.99)(screws)
-1 Ametek dc motor ($60.00)(generator)
-frame made from 2x4 ($11.00)(frame)
Total of::: $164.08
Goal is to generate 100 watts at 35km/h
So I hope you guys enjoy this one like the ones before it.
Regards
Faroun
STEP 1: Vanes
Later, while it was spinning I realized that it was losing air in the middle, so I modded the vanes by adding another section of pvc in the middle. The photos will explain more of what I am saying.
But in future I should have cut the vanes to shape and that will double the cost of the pvc to $75.00.
note: I rendered a drawing for you to see how to cut your vanes (PVC).
I hope I explained it correctly..
And A 1/8" hole is drilled at each side and it is .5" from side and 1" away from bottom.
Again you have to alternate the pvc pipes because of the flange end.
That is it.
Regards
Faroun
STEP 2: Mount Brackets
I drilled a 1/8" hole around the circumfrance every 2" to give me 8 holes.
I also drilled out 1/2" center hole for the top axle and bottom axle.
Make sure the holes line up, otherwise you will have uneven height for the vanes and that will suck.
Regards
Faroun
STEP 3: Center Bracket Assembly
I actually was looking for a 8" one but could not find one fast enough, maybe later, so I used a 9" instead. I simply screwed it in the center of the turbine, again make sure it is in the center other you will get a bad wobble.
Easy sh!t there nothing else to say...lol
Regards
Faroun
STEP 4: Vane Assembly
I have included all the pics that will describe the assembly action.
I am not the best teacher but I compensate with my photos.
Regards
Faroun
STEP 5: Result
Otherwise, go to youtube, it is there.
Regards
Faroun
11 Comments
SachinC36 4 years ago
pdionne 11 years ago
mstehmeier 11 years ago
it should be designed like a tower fan blade. otherwise you have dead air pockets reducing efficiency
faroun 11 years ago
sam
mosesravoori 14 years ago
thetwobros4 15 years ago
static 15 years ago
faroun 15 years ago
vawt+generator+charger controller+battery+convertor+appliance.
all i am showing here is vawt+off the shelf dc motor/generator(pmg)
if you need a custom build generator go here please https://www.instructables.com/id/Faroun-Savonius-Wind-Turbine/
thanks
faroun
faroun 15 years ago
PKM 15 years ago
Have you measured output wattage at your usual wind speed? Also, slightly more involved question, do you know how these perform with other objects close to them? I'm imagining a big rectangular frame the size of a barn door full of them- at maybe 50 watts each that's a respectable amount of power.
faroun 15 years ago
