Vanity Mirror With Lights
Intro: Vanity Mirror With Lights
This instructable is of a Vanity Mirror with Lights that was a fun project to make. These are very expensive to buy so I decided to make one. Hopefully if anybody decides to make one I can help you save time and money in doing so. It took me several trips to the hardware store to get all the supplies needed, which I don't mind doing. Basically this project is one flat MDF board for the top, and that is nailed to a frame. The frame is 1 inch by 4 inch. I cut circle holes and square holes, did sanding priming and painting. The wiring in this project is fairly simple to wire. This is were I learned to make wood projects
STEP 1: Get All Supplies
card board for proto type Free found
36 x 33 inch mdf board 5/8'' thick Free from my work, other wise 15.00$ get a 4 ft x 4ft and cut it
1'' x 4'' wood boards 12 ft total 10$
6 bulb vanity bar 22$
2- 4 bulb vanity bars 35$ this is were you can get the vanity strips
electrical wiring 10 feet 10$
wire nuts for light wires 5$ couple boxes
3 plastic electrical boxes 3$
3 "L" bracket mounts 3$ you could uses two a box and get six
2 power plugs 2$ I used white could get black ones
1 dimmer switch 10$ dimmer switch here
three pronge plug free cut a cord from something else
light bulbs 40$ depends on the bulbs you uses....daylight these are the bulbs I used from amzon
4 mirror clips 2$ here are the mirror clips
primer 4$
STEP 2: Gather Tools Needed
Tools
cordless drill drill here
circular saw could use other saws too
jig saw jig saw for specialty cuts
finishing sander example here
hammer I never new there were so many types of hammers
straight edge measuring makes all the difference
ruler having different size rulers
tape measure having a good one of theses makes a difference
pencil I like to use drafting pencils
1 1/2 inch drill bit this is for cutting holes for light bulbs
wood putty filling holes
wood glue I would suggest gorilla glue
STEP 3: Start With Vanity Bars
The first thing you wanna do is get the fixtures for the bulbs. You can choose which ever you like best which will determine your measurements for everything else.
I went with a 6 bulb vanity for the top and 4 bulb vanity strips for the sides. The center of the light bulbs are six inches apart. So for the 4 bulb vanity's i measure to make them even mount apart.
I did my measurements on a prototype piece of card board.
these vanity bars cost me 60 $ total. I ordered mine here
When putting the vanity bars on the prototype I left 1 inch on the sides of them for where the 1 inch wood board frame is going to go, and marked where the vanity bars are gonna fit and marked where the holes for the light bulb fixtures will. and then cut the holes out of the cardboard prototype.
This made my top board demensions to be 36 x 33 inches.
STEP 4: Electrical Box Square Holes
You can choose how ever many outlets you want. on my project I am cutting three holes. One for switch in the center and two holes for the power plugs.THis is just kinda Cool I wanted these at the bottom I measure to make sure the electrical boxes would not interfere with the 1 inch frame board. the I marked the center of the front and traced an electrical box where I wanted the hole to be. Then I measure an even amount distance for the two holes for the power outlet plugs to go.
STEP 5: Measure Twice Cut Once
The first cut your going to be making is cutting the frame. I cut a square peace of wood to the demensions of 36 x 33 inches. I layed the prototype down to make sure that was the same as the 36 x 33. I used a cicular saw and got it straight. otherwise could use a table saw to get the right size front board.
Then I traced the holes from the card board prototype onto the front wood just cut.
I used a cordless drill and a 1 1/2 inch drill bit to cut out the holes for the light bulb fixtures.
To cut out the square electrical boxes I drilled a hole in corners big enough to fit the blade of the jig saw to fit in. Then I used the jig saw to cut out the squares for the electrical box.
Then you need to cut the 4'' x 1'' board for the frame. i cut to pieces the length of 36'' for the top and bottom.
then cut 2 pieces 31'' for the sides.
Speaking of cutting heres one of the credit card cutter things
STEP 6: Attaching Frame
to attach the frame you first need to pre mark the holes for where you are going to drill the holes for the nailing the top board to the frame. the frame board is 1'' so i measure in from the edge 1/2 inch and drew a line in from the edge. i marked holes three inches apart. before pre drilling the holes I glued the frame to the top board and put wieghts on it to hold it together. once the glued dryed i pre-drilled holes for the nails. Then nailed in the nails where i marked the pre-drilled holes.
STEP 7: Sanding, Putting, Priming & Painting
Wood Putty
After you have the frame connected you wanna cover up the nails with putty so are flush with the wood. also you wanna add wood putty where the wood connects to each and any other spots you feel need to be filled in. Then once it dries you need to sand everything down so it can be primed and painted.
Sanding
You want to make sure you sand the vanity to make it look the best possible it can. I used a finishing sander with a fine grit paper. The better you sand the easier the primer will stick to the wood.
If need photos tips
Priming
I used sandable spray primer. After I sanded it i clean off all the dust a wiped down the vanity before spaying the primer. Using the primer helps the paint stick better and last longer.
Painting
I used black spray paint for the final finish, it took me two cans. When i painted and primed i lifted the vantiy off the ground so that the paint didn't stick to card board underneath it. Also if you have the electrical boxes already mounted it would be a good idea to cover up the screw holes so paint doesn't get in them.
STEP 8: Mounting and Wiring Electrical
Mounting
To mount the electrical boxes I used plastic boxes. You put them in the pre-cut holes so that the box is flush with top of the top board. I needed to use metal "L" brackets to mount theses to the back of the board. Then I mounted the vanity bar strips using screws.
Wiring
To wire the vanity i started with a three prong plug. I cut off the end and had the three wires coming out. There is a blue green and brown.
Blue - nuetral
Green/yellow - ground
Brown- live
I connected these to the first plug. Then from the first plug I have wires going to the second plug, and from the second plug going to the switch. From the switch I have the vanity bars hooked up. I connected all the vanity bars together.
STEP 9: Closing
Attaching the mirror. I glued the mirror first and then I added four mirror clips to help secure it. The size of the mirror I used was 21 inches by 24 inches.
This was a fun project to make, learned a few things making this project. I hope if you choose to make a vanity mirror this can be helpful for you.
7 Comments
kitty82589 10 years ago
This is the coolest thing I've ever seen! Way better than paying $800 for the Vanity Girl Hollywood ones you buy online. Nice work! That's a pretty kitty too if I say so myself.
Decor Snob 7 years ago
Hi, Nice Write Up! I'll add this to the list of tutorials for building a vanity mirror with lights over on my blog. Can you post a link to the lights you bought to make this?
ElleDetris 8 years ago
WOW! THIS IS AWESOME!! Is there a place to borrow all of these tools? I live in Washington State and definitely don't have any of these nor the space :(
I would be REALLY interested and SOOO APPRECIATIVE if someone would be interested in making this for me & I would purchase it with an additional labor credit from you :) It is WAY better than anything bought online! I just don't have any of the tools, time or much of the time with my kids - please email elise.detris@gmail.com
Thank you!
sosclosetsandfurniture 9 years ago
Nicely done. I've got a tentative project to do for a modern style vanity with a lighted mirror. Very helpful! Thanks!
soleya 9 years ago
Can you use 3/4" thick MDF board?
dominque.rochelle 9 years ago
so for me to better understand...you connected the lights to the switch. did you also connect the lights to the outlet i was a tad confused.
josbor11 9 years ago
Have a few questions. In one of the pictures in step three where you have the vanity light bars laid out they are much larger and more block like than they are in the first picture you have in step eight. Did you take the covers off the light bars or something? They look stripped down a bit. Also, can you just use MDF or particle board for the 4 x 1 frame boards?
