Vape Box
Intro: Vape Box
As a new convert to E-cigs I noticed a lack of anything vape related on here. These are pictures of a carrying case I've been working on. The cases I had seen just weren't ME and the DIY is one of the things I love about it.
This case is a dart case with the inside stripped out and lined with foam. I'm not so good with the foam, or maybe I'm working with the wrong stuff but it's not turning out as tight as I wanted. When finished I hope to line it. Any input on foam? Anything on vaping??!
Steps:
Remove lining from your chosen case.
Outline and draw what you want in there.
Cut out a template.
Cut out the foam.
Put together.
Please rate~ thanks!
Where on here would this go??!
Steps:
Cut out a template.
Cut out the foam.
Put together.
12 Comments
Modiculous 6 years ago
Nice box! Good to have a decent place for safe storage for trip and otherwise, and there just fun to have and build I agree.
Andajus 7 years ago
It would be a great idea to put a little solar panel on the top. It wouldn't be a great way to recharge the battery but it's still something :D
FumaKilla 8 years ago
Welcome to Vaping! :)
bkelly1012 10 years ago
cj8675 10 years ago
raymondroot 11 years ago
that will give you the best fit available to anyone
l8nite 12 years ago
Winged Fist 12 years ago
esemjay 13 years ago
Next wrap your vape in cling wrap or even a plastic baggy just be as tight as possible. Grease the outside with cooking spray, vaseline, what every oily based lubricant you have. Now take tow panes of glass. Grease those as well. Place your template and vape between the panes. This will give you the thickness needed. Clamp everything together. Enclose the edges with more plastic or what ever you have. Use "Great stuff" foam and fill the voids between the panes. The plastic template should act like a separation point for your make shift "mold". Cover the whole thing in felt.
tomraman 13 years ago
bryanwithaytx 13 years ago
Now send me that foam!!!
mdog93 13 years ago
Just an idea
