15 Minute Vegetables Tacos (from a Meat Guy)
Intro: 15 Minute Vegetables Tacos (from a Meat Guy)
I'm a meat eating guy. I hunt. My idea of a great meal was traditionally a big steak.
But I also was recently diagnosed with high blood pressure. And since my grandfather had a bad stroke, and was never the same until his death, and then my dad had a stroke (small one but still), I figured maybe I don't like steak and bacon as much as I want to see my kids grow up.
Honestly, sometimes I add in a few ounces of chorizo (it doesn't take much to add flavor) or a little bit of chicken breast. I like it but I don't have to have it.
You can also see there is no salt. Add it to your liking. Blood pressure and salt don't like each other. So I don't.
Nutritional information:
33 calories in a zucchini
30 calories in a yellow squash
44 calories in onion
24 calories in bell pepper
Olive oil 119 calories per tablespoon (2)
87.5 calories in tomatoes
385 calories in black beans
That makes this mixture 907.5 calories total. And it fed a family of 5. With leftovers. So we ate about 60-75% of it.
Of course there are calories in the tortillas and avocado, as well as cheese and other things you may add.
Entire cooking time is 15 minutes. Assuming you prepare beforehand this is a great last minute meal. Honestly even the prep, for me, is way less than 10 minutes.
STEP 1: Ingredients
3 zucchini
1 yellow squash
1 onion
1 bell pepper (which I forgot to buy so I used frozen)
Cilantro
1 can black beans
1 can of Rotel (I'm cheap... I used Kroger brand)
1 TBSP cumin
1 TBSP chili powder
STEP 2: Cilantro
Untie it and put it in a bowl of water. Shake it around. The dirt and sand stay.
The stalks of cilantro have a lot of flavor, but they super stringy. I chop the very ends off... And then chop the rest of the stalk very fine.
Put it in the pan with the olive oil. On medium heat.
STEP 3: Onion
Anyways.
1. Cut the ends off
2. Sit it on one flat end. Cut it in half.
3. It's now really easy to pull the skin off.
4. Turn it so a flat end is towards you. I cut from the outside to the center. This keeps the slices consistent.
5. When you are halfway through, just turn it around in one unit. Otherwise it's super hard to cut the other direction. For me anyway.
6. Once it's sliced, turn it 90 degrees. At this point you can cut it small to dice it. For this recipe I only wanted to cut it in half.
In the pan it breaks up perfectly.
STEP 4: Cilantro, Onion, and Garlic
STEP 5: Add the Gourd
It's going to feel like you need more oil or something... But you don't I promise.
Just put a lid on it, get your spices ready and start opening your cans.
STEP 6: Spices
STEP 7: Beans and Rotel
This is because of the sodium. You don't have to do this if you don't care about being healthy. In which case you probably aren't reading this.
Dump them in... Mix them up and crank the heat so the liquid will cook off.
STEP 8: Corn Tortillas
And so I always used flour. But flour tortillas are made with white flour and lard. Delicious... But not exactly healthy.
I will sheepishly tell you that I picked up the secret to good corn tortillas from the movie "Turbo".
Anyway... Take 2 tortillas together. Spray the pan with cooking spray. Put the tortillas in the pan together. Spray the top of the second one immediately. This traps the moisture and the 2 tortillas will join together.
You will see it starts to bubble up. When you see that... Flip it as a unit.
You'll notice the cooked one is a little bit smaller because the water is evaporated (I guess). When the bottom one shrinks up, pull it.
They should kinda stick together. Don't separate them. You'll use 2 per taco.
Done this way, the tortillas are both crispy and still soft inside.
If you don't care about sodium, it's amazing to salt them before you flip them. Like eating off a chip... Dang I miss salt.
STEP 9: Back to the Mixture.
I chop a little extra cilantro and add it at the end.
The mixture cooks a total of about 15 minutes.
STEP 10: Plate It
Cheese is great on it, but again with the dying thing, so I don't. My daughter does.
STEP 11: Leftovers
Usually I add it to an omelette (hey I am not actually a vegan) the next morning. Also pretty good.
9 Comments
YamiEridani 7 years ago
Does this mixture freeze well?
jls99 7 years ago
SniderThanYou 8 years ago
These look excellent! I also don't eat meat very often, and have been looking for more options that don't involve a meat substitute like tofu or tempeh. I'll be trying these soon. Thanks for posting. Best of health!
jls99 8 years ago
If I crave a burger or steak I go get a really good one. I wouldn't say it's a meat substitute but it's a great meal.
CorgiCritter 8 years ago
This looks pretty good! I love my meat, but this looks really tasty. Does it taste (Sort of) like a "real" taco?
jls99 8 years ago
But I didn't have any one time and it was still great. So now I just make it this way.
gumby_kevbo 8 years ago
Start by cutting off only the pointy end, leave rooty end on. Stand on cut off end and cut in half, taking care to leave root on both halves. Peel off dry layers.
Now slice each half in segments as you show, but take care not to slice through root end. The root end will hold it all together.
For diced, Now start cross cutting opposite root. If you want strips for fajitas, just cut off root end and you are done.
Took me way longer to type than to do.
