Velcro Face Mask
Intro: Velcro Face Mask
This is a Velcro strap face mask with PM2.5 filter pocket.
STEP 1: Gather Supplies
-Fabric outer layer: .25 yards (tightly woven cotton or nonwoven material)
-Fabric lining: .25 yards (non stretch soft cotton)
-Bias tape: Extra wide
-Velcro: 10 inches
-PM2.5 filter
STEP 2: Cut Pattern
-Front main panel: Cut 1-2 depending on how many layer you want for protection. This can also be determined by how loose your fabric is. Just keep in mind the more layer the more protection.
-Front and lining bottom panel: Cut 1 outer layer fabric. Cut 1 lining fabric.
-Center lining panel: Cut 1 lining fabric
STEP 3: Hem Lining
-Mark the hem lines onto the lining panels.
-Both sides of center lining panel and only the inside edges of the lining side panels.
-Roll over and pin edge.
-Sew at .25 inch seam allowance.
STEP 4: Lining Peak
-Place the right sides together.
-Sew as close as you can to the edge.
-Trim the point close to the seam.
STEP 5: Front Main Panel Peak
(Repeat previous step on the front main panel)
STEP 6: Add Bias Tape
-You can use made bias tape, make your own bias tape, or bias tape attachment. All methods work.
-Place the wrong sides of the outer layer and lining together.
-Add bias tape to the top straight edge of the bottom main panel.
STEP 7: Add Twist Tie
-Slide the twist tie or other bendy metal object into the bias tape.
-Make sure the twist tie is centered in the bias tape.
STEP 8: Assembling Panels
-Place the wrong sides of the Center Lining and Front Main Panel together.
-Line up the bottom seams and top notch.
-Place the Bottom Main panel on top of the lining with right sides together.
STEP 9: Bias Tape Back Sides
-Bias tape only the back sides of the Front Main Panel.
STEP 10: Adding Velcro
-Cut 4-5 inch strip of Velcro.
-Velcro will overlap so one strip will go on the outside and one on the inside.
-Place in the back center of the Front Main Panel.
-Sew along the outside of the Velcro.
STEP 11: Bias Tape Top and Bottom Edge
-Add bias tape to the top and bottom edge.
-Leave .5-1 inch at the start and end of each edge.
STEP 12: Sewing Off Ends
-With the remaining bias tape. Fold over the ends towards the inside.
-Tack stitch each corner.
STEP 13: Add PM2.5 Filter
-Last step is to add the PM2.5 filter to the inside pocket.
-If you are having trouble finding the filters. Here is a link to making your own from household materials : https://youtu.be/ySgsARkOxkM
2 Comments
TheresaS54 4 years ago
I am planning to make about 40 of these for clinic in town.
Please reply. Theresa
MyBestestThing 3 years ago
Post and let us know what you end up doing, okay? Stay safe!
