Velveeta Beer Cheese Broccoli, Spinach, and Cabbage Soup With Steamed Bagels
Intro: Velveeta Beer Cheese Broccoli, Spinach, and Cabbage Soup With Steamed Bagels
I am in college and I recently got a Ninja Foodi as a gift and so I have been trying to use it more often and one of my favorite new ways to use it is to make one pot soups with a bread side. To this, I made Velveeta Beer Cheese Broccoli, Spinach, and Cabbage Soup with Everything Bagels. I try to include the most ingredients I can into each soup and this one is no different. I especially like this soup because the flavor is uniformly cheesy without overdoing it as the vegetables balance out the velveeta. I use beer in the recipe just for the sharp/almost aged flavor note it gives to the cheese (all alcohol evaporates during cooking).
NOTE: the ingredients for each step are listed with that step as well as combined in the Supplies step
NOTE: the steps for making the bagels follow start with overall recipe Step 7 (labeled Step 7: Bagels - 1: Autolyze)
STEP 1: Soup - 1: Chopping What Is Not Chopped
Very finely dice to about 1/4 by 1/4 inch in size pieces
Chop cabbage head in half
Chop each half cabbage head in 6 "steaks"
Chop each cabbage steak into 3 parts (going for about 1 inch cabbage chunks)
I find it's easiest to cut and cook the entire cabbage head at the same time as the cabbage keeps well in sandwich bags.
Ingredients for this Step:
Soup Base:
- Sweet Onion: 1/2 cup very finely chopped
Soup Add-ins:
- Head of Cabbage: half head
STEP 2: Soup - 2: Pressure Cooking the Add Ins
Cabbage:
- Put all cabbage pieces into Ninja Foodi
- Secure Pressure Cook lid and turn the steam release valve to Seal
- Pressure cook on Hi for 2 minutes then Quick Release
- Drain cabbage
- Spread onto plates to allow for steam to come off and cabbage to cool quickly
Broccoli and Spinach
- Put all both bags of vegetables into Ninja Foodi
- Pressure cook on Hi for 1-1.5 minutes then Quick Release (2 minutes will make the broccoli mushy)
- Drain vegetables
- Spread onto plates to allow for steam to come off and to cool quickly
What is Quick Release?
- Quick Release is when you turn the steam release valve to Vent immediately once the Ninja Foodi timer goes off for steaming, pressure cooking, and etc. functions that build up pressure in the Foodi
What size Ninja Foodi?
- I used a 5 quart one and the cabbage I really had to squeeze in but that doesn't matter as long as it fits. Otherwise, the 5 quart works perfectly for the rest of the soup so I would say any size Ninja Foodi.
Soup Add-ins:
- Frozen Chopped Broccoli: 16 oz bag
- Frozen Chopped Spinach: 16 oz bag
STEP 3: Soup - 3: Starting the Base
To the Ninja Foodi, add the onions and butter and sauté on a high setting until onions are soft/tender and completely translucent
- Note: It is ok if the onions crisp up a little too much/brown
Next add the flour
This will make a very thick paste/scraggly mess
Soup Base:
- All Purpose Flour: 5 tablespoons
- Butter/Margarine/Spread: 3 tablespoons
STEP 4: Soup - 4: Incorporating the Soup Liquids
Add beer to thick paste made in last step
THEN add cubed velveeta
- NOTE: velveeta has only one passion in life and that is to burn at the bottom of the pot at any given opportunity, if you put the velveeta first it will most likely burn before you know it
- NOTE NOTE: CONSTANTLY stir the soup from now on to prevent the velveeta from burning on the bottom of the pot--- you will know it has burned when you feel with your spatula that the bottom of the pot is no longer smooth---if this happens just scrape it and continue but it will disperse overcooked velveeta into the soup
Once Velveeta melted add the water, milk, and bouillon cubes
Cook until bouillon cubes dissolve and the soup so far is thoroughly mixed
Soup Liquids:
- Velveeta: 16 oz block
- Pabst Blue Ribbon Beer (any cheap beer): 1 cup
- Chicken Bouillon Cubes (I used Knorr): 2
- Water: 4 cups
- Milk (any percent): 2 cups
STEP 5: Soup - 5: Soup Addins
To the soup so far, add in all of the broccoli and spinach made before. Also add in about half of the one head of cabbage.
The amount of each add in is really up to individual preference, I sometimes add more or less of one depending on what I have left from a previous batch.
Other good add ins:
- black eyed peas (if you want them soft, pressure cook alone for 3 minutes)
- chicken
- carrots (much like broccoli these will turn to mush very quickly)
Soup Add-ins:
STEP 6: Soup - 6: Soup Complete!
You can now enjoy your Velveeta Beer Cheese Broccoli, Spinach, and Cabbage Soup! I like to serve it in a mug to hold and warm my hands.
If you want to add seasoning, I recommend using Tony Chachere's Seasoning to taste ( I use about half a tablespoon per cup soup which I add right before I eat each cup)
STEP 7: Bagels - 1: Autolyze
(This can be done in the Ninja Foodi pot- I just used a bowl since I was cooking the vegetables at the same time)
To a bowl, add 4 cups of the flour along with 1.5 cups of water-- allow to sit for 1 hour
This step is called Autolyze: I do this because it helps speed the kneading time and makes it easier to knead by hand, however it can also help develop more complex flavors in bread doughs
Bagel Ingredients:
- All Purpose Flour: 4 cups (of 5.5 total)
- Water: 1.5 cups (of 2 total for dough)
STEP 8: Bagels - 2: Proof Yeast and Mix
How to proof the yeast:
- In a cup, mix:
- 1/2 cup warm water (MAX 115 degrees (if its to warm for your skin its to warm for the yeast))
- one packet of ACTIVE yeast
- 1 tablespoon of brown sugar
- Let mixture set for 10 minutes
- the yeast should foam up and rise dramatically in the cup and up the sides of the cup---if not, the yeast was not active enough or the water was too warm so start again
Add proofed yeast mixture plus 1/2 tablespoon of brown sugar to autolyze from previous step--- mix to combine
Once combined, add salt, oil, and 1 cup of flour, use the rest of the flour to dust surface to knead the dough on
Knead until dough becomes smooth and elastic in texture (like a baby's bottom)
- TIP: allow the dough to rest for a few minutes at a time and you will notice an improvement when you begin to knead again
- At this point, you should be able to take about a golf ball sized portion of dough and stretch it between your fingers, you should be able to see light through the dough without it breaking apart
- IF THIS DOESN'T HAPPEN: I spent like 20 minutes kneading this and while it held together for this test, it was not impressive by any means (not able to stretch till super thin without breaking), THIS IS OK (if you are happy with the bagels that are shown in this recipe)
Bagel Ingredients:
- All Purpose Flour: 1.5 cups (what is remaining after last step)
- Active Yeast: one package
- Brown Sugar: 1.5 tablespoon for dough
- Salt: 2 teaspoons
- Water: 1/2 cup (what is remaining after last step for dough)
- Neutral oil (canola, olive): 1 tablespoon for the dough
STEP 9: Bagel - 3: Double in Size
Liberally oil outside of dough ball and put into bowl
Cover with moist towel
Place in warm area like oven with light on until the dough just about doubles in size/until “doubled in bulk” which can be tested by poking a finger in dough without the dough springing back (takes about an hour)
Bagel Ingredients:
- Neutral oil (canola, olive): amount to coat the dough
STEP 10: Bagel - 4: Divide and Rise
Divide the dough into about 10 equal portions
Poke a hole through each portion and make into bagel shape (mine are rectangular-ish because I cut the dough in rectangles to portion them)
Allow to rest for about half the time of the last rise (about 30 minutes): this second rise produces a finer grain in the dough
STEP 11: Bagel - 5: Steam and Bake
Steaming the Bagels:
- Into the Ninja Foodi Pot, pour 1 cup of water and 1/2 tablespoon of brown sugar
- Place the risen bagels onto the Ninja Foodi metal wrack
- Secure the Pressure Cook lid and turn the steam release valve to Seal
- Steam for 1 minutes then Quick Release
- Remove the Pressure Cook lid
Baking the Bagels:
- Pour the remaining liquid from the steaming into a cup for use in the next batch of bagels
- Close the Air Frying lid, press Bake/Roast at 400 degrees for 7 minutes
- Check for internal bagel temperature of about 180 degrees (occurs once about 4 minutes have passed)
- Quickly wipe egg wash on one bagel at a time and add seasoning if so desired (egg needs to be done quickly so seasoning will stick)
- Bagels are finished when internal temp is about 190 degrees (just about when timer ends)
Why steam and not boil the bagels before baking?
- Even though I love bagels, they can be tough to eat with my jaw issues. Steaming the bagels instead of boiling produces a fluffier and less dense crumb that is easier to chew.
Why add brown sugar to the steam water?
- Adding sugar to the steam water will make give the crust a that shinny crust that bagels are known for.
Bagel Ingredients:
- Brown Sugar: 1 tablespoon for steaming liquid
- Water: 1 cup for steaming liquid
STEP 12: Bagels - 6: Bagels Complete!
Your bagels are complete! I cut a bagel and put it on top so you can see the inner texture. They are pleasantly soft but still very bagel-ly!
Pairs well with almost any soup--especially the one included in this recipe ;) !
LoriW111 2 years ago
