Vibrobot Build
Intro: Vibrobot Build
This is a simple way to pleasure a simple mind.... or a complex one who needs a break, so fun for most ages.
Also once your done you can DECORATE it!
STEP 1: Things You'll Need
1) A simple and cheap vibrating toothbrush
2) 3 1-1/2 in wires of different colors.
3) An altoids can! (big enough to hold a AA battery)
4) AA Battery
5) Metal Hanger
6) 2 nuts
7) 2 screws
8) 2 washers
9) wire tie
10) sodering spool
11) hot glue sticks
12) a plastic bag to hold all your stuff
Tools:
Wire Cutter
Wire stripper...(teeth)
soder..er
pliers
screwdriver
hot glue gun
"Safety Equipment":
goggles
gloves
4) AA Battery
5) Metal Hanger
6) 2 nuts
7) 2 screws
8) 2 washers
9) wire tie
10) sodering spool
11) hot glue sticks
Tools:
Wire Cutter
soder..er
pliers
screwdriver
hot glue gun
"Safety Equipment":
goggles
gloves
STEP 2: Step ONE! After You Gather Materials
you will need to cut apart your metal hanger,
the bend will be where it attaches to the bot, so longer down the middle the longer the legs.
then you will need to bend the corners down so that they will fit much better to the bottom.
STEP 3: STEP TWO! Take Apart Your Toothbrush
go buy a cheap vibrating toothbrush,
pull off the bottom
take your pliers and fish out the motor
or
thump it, open end down, into your hand...
either work.
you slip some wire through a little hole and fold over
soder the one end to itself
pull off the bottom
or
either work.
STEP 4: STEP THREE! the Energy Source!
take one end of a wire and sodder it to the flat end of a AA Battery,
then take yet another wire and soder it to the end with a bump on it
let cool!
wrap the battery(and both ends) with electric tape.
let cool!
STEP 5: STEP FOUR! the Body
four holes will be poked onto the tin can...
two small holes on the top(for the two battery wires)
and two slightly larger holes at the bottom(big enough so that screw will fit in it)
the two smaller holes will of course,
be on the top and close to one another on one side of the lid
and the two larger holes will be on the bottom evenly spaced out.
STEP 6: STEP FIVE! Building the Legs
this step is a little difficult to do on your own, so a buddy would help, alot.
first you place the washer on the outside bottom of the bot,
then put the screw in and the nut on the inside,
screw it on just enough to stay
then put the bent end of the hanger around the screw,
and screw it in you may need pliers and a screw driver...
do this for both legs.
STEP 7: STEP SIX! the Guts...
now that the body is built,
you will take the two battery wires
and pull them through the lid of the can,
then close the lid...
then zip tie the motor to the body,
high tech- i know.
now sodder one of the battery wire to the motor so all thats needed to close the circut is to put the other wires together....
OR
you can twist one of the battery wires with the motor wire,
so all that would be needed to complete the circuit would be to touch the last standing battery wire to the spring on the motor.
your choice.
high tech- i know.
OR
your choice.
STEP 8: VOILA! Your Done...
now that your bot is built, you can take over the world....
or better yet, get an A from Mrs. Black!
now review, do and bother either of the Mrs. whites with a
"mysterious buzzing noise"
bzz bzz Im Donna Greek....
bzz bzz I'm Sandra Restrepo...
bzz bzz ...
got any questions, just ask!
http://www.youtube.com/watch?v=GYponmlMWrQ
bzz bzz ...
4 Comments
aimenbadi 9 years ago
what it do ?
webmanoffesto 11 years ago
TSC 14 years ago
lemonie 15 years ago
