Introduction: Vinyl Record Bowl
This is a fun way to reuse old, scratched records and create your own unique display bowls. If you don't happen to have records already, you can usually find them for under a dollar at your local thrift store.
Step 1:
Time : 15-20 minutes
Materials
- Vinyl record
- Baking sheet
- Heat safe gloves or oven mitts
- Oven safe bowl, about 4-5 inches for base diameter
- Small bowl or other heat safe item of similar weight
Materials
- Vinyl record
- Baking sheet
Step 2:
Move a single oven rack to a low position in the oven and preheat the oven to 200-225°F
Step 3:
Place the bowl upside down on the baking sheet
Step 4:
Center the record on top of the large bowl, and weight the center with the small bowl
Step 5:
Place in the oven and heat it for 4-8 minutes
Step 6:
Keep a close watch and remove when the record drapes over the bowl
Step 7:
Wearing gloves, pull out the sheet and quickly mold the record into desired shape
Step 8:
Let it cool for 10-15 minutes
- If you're careful, you can actually mold it with your hands straight out of the oven. Just use a mitt to handle the bowls and pan.
- If you mess up, stick it back in the oven and try again. You won't do any damage reheating it.
