Vinyl Door Curtain
11,581
35
12
Introduction: Vinyl Door Curtain
So I found around 100 old records in the dumpster at work and had no idea what to do with them all. I looked at some of the projects on this site, made a few, then came up with my own:)
Materials:
Wooden plank cut to size of door frame
Heavyweight picture hangers
Heavyweight hanging eyes
Heavyweight string or ribbon
About 40 old records (depending on door size and user error)
Superglue
Dremel, drill, or punch and hammer
An empty door frame that can support a curtain
Protective surface that can be drilled or hammered on
Step 1: Picking a Door Way
Pick the desired door frame you would like to place your curtain on. I chose the outside frame of my bedroom door since my door closes in the opposite direction of the placement of the curtain.
Step 2: Measuring
Once the desired placement of the curtain is set start to measure out the records. My particular door frame is 4 records across by 6 records down. Door frames do vary, so measure first!
Also clean the record if desired:P
Step 3: Planning
Place all the records in a pattern you would like, move them around till you get the desired effect. I ended up using 4 records across by 6 records down. When at the desired effect you are ready for the hard part (that took the majority of the time).
Step 4: Beginning Drilling
For this part I highly recommend a drill or Dremmel tool, but unfortunately in my apartment we are ill equipped in the tool department. I ended up using a pattern punch and a hammer. If you are like me and must use the caveman technology and live on a second or third floor apartment, please be considerate of your neighbors downstairs and dont hammer(or use loud tools) at awkward hours.
To begin:
Place record on a protective thick surface, such as a thick piece of plastic or wood
Step 5: Drilling
For this step you need to be very careful! Records are very delicate and break really easily!!!
Id say I broke around 30 of them today during this step:P This is the most annoying and tedious part of the project. Be prepared to spend about 3 hours doing this.
For the first hole:
Start by making a very small prick into the record, about the 3rd groove from the edge in.
Very carefully start to make the hole untill its at the desired size to pass your cord through
If you crack a record, pull another out of your pile and start again, this time drill slower and more carefully.
For the second hole:
Repeat first hole process, same system, 3rd groove from edge. Try to make the two holes line up, but thats up to you, crooked records look pretty cool:)
Step 6: Hole Placement
Your holes should look somewhat like this, they can be made bigger or smaller due to your cord size.
Step 7: Putting Things Together
Once the tedious part is done you can start to string your records together. I alternated colors between white satin ribbon and yellow embroidery thread, again its up to you to do what you want with your project!
Stringing:
Take cord and string through hole and tie, leaving about 3-6' of remaining cord. Cut off longer piece and repeat process with next record. When tying knot about 3-4 times for extra durability. Repeat process until done. If cord breaks, snip it off and try again.
Step 8: Rows
By this point you should have 4 very long rows of dangling records. Check out the process and make sure you like the final result before you move on to the next step.
Step 9: Measuring Plank
Measure your plank of wood to the top of your door. I had to trim mine, and since we are in the dark age of tools i had to use a serrated edge steak knife. If this applies to you as well, be careful not to get caught or else you will get in lots of trouble!! I wanted to paint my wood, but didnt have the time:(
When done place picture hangers into wall and measure hanging eyes (attached to wood) with hooks
Step 10: Attaching Records
This step is pretty self explanatory (and i got distracted and forgot to take a photo of this step:P). Take the bits of cord hanging from the tops of the chains and add them to the plank. Superglue the cord if it feels loose or unsecure.
Step 11: Hanging
Hang up your curtain and marvel at your hard work and a job well done!:)
Do be careful not to let your curtain get stuck in your door jam.
Hope you had fun :)
Be the First to Share
    • Anything Goes Contest 2021
    • Raspberry Pi Contest
    • One Board Contest
      One Board Contest
    12 Comments
    lumpee
    lumpee
    10 years ago on Step 5
    Perhaps a pair of pliers and a heated nail would work for the holes.
    pyromonkey
    pyromonkey
    Reply 10 years ago on Step 5
    Thats a really good idea
    amberella1964
    amberella1964
    11 years ago on Introduction
    Just a thought...as I have hundreds of old records in rough shape I was making bowls out of some and was amazed to find that most if not all of the scratches disappeared during the heating process in the oven. Soooo, it occurs to me that if you put the record in the oven, just long enough for it to get soft and malleable , pull it out, lay it on a wooden board and use the hole punch then....it would still harden flat but would have the hole in it...and no breaking. Plus it would be all shiny and new again. (the vinyl part anyways).
    Just a thought as I said, I will try it out myself later because I love the idea of this curtain!
    Amber
    pyromonkey
    pyromonkey
    Thats a great idea!! (Srry Im just noticing you commented) While its hot, make the holes. Or even heat the hole puncher before putting it into the plastic.
    JessG516
    JessG516
    12 years ago on Introduction
    It looks really neat. My roommate has a bunch of records. I'm going to see if she will make something like this. Is it a pain in the butt to walk through?
    pyromonkey
    pyromonkey
    Reply 12 years ago on Introduction
    Thanks :) Not really, its like a beaded curtain kind of. It does hurt if you bump into one of the records unexpectedly though:P
    canida
    canida
    13 years ago on Introduction
    Looks totally sweet! The photos are a bit blurry, but it's still an awesome project.
    pyromonkey
    pyromonkey
    Reply 13 years ago on Introduction
    ty:) ya my camera is being annoying and not taking proper pictures >_<
    GorillazMiko
    GorillazMiko
    Looks cool. I did this with those huge bubble things you get in the UPS packages, it looked so weird. Awesome job.
    canida
    canida
    Ooh, neat! Did you take pictures?
    GorillazMiko
    GorillazMiko
    Aww man! I forgot. :-( It's not there anymore, my dad made me take it down. But someday, when I get more, pictures will be definitely taken.
    pyromonkey
    pyromonkey
    wow, that sounds like it would be a cool idea. heh, go figure:P ty:D
