Introduction: Violin/Guitar Clothes Hanger
Recycling woods used in the manufacture of guitars, own design clothes hanger shaped Violin/Guitars, idea can be applies to other models and finishes.
What You'll Need:
• Plywood board 12mm thickness
• Maple wood
• Steel piper, 10mm exterior diameter and 8mm inner
• Varnish
• Stain (optional)
• Woodworking tools
You can also check out my website! www.paoson.com
Step 1: Video and Instructions
Precut Plywood board, then download DXF files for CNC and preparing machining programs. Draws knobs in maple wood and sand all pieces...
You can use the stain before or after of the first lacquer coat, use 320 grit sandpaper between coats. See the video for more information.
Shelving Contest
4 Comments
7 years ago
Beautiful concept. You could also use the other half as a shelf coming off over the coat rack part. Would make for a cool illusion as well. =)
7 years ago on Introduction
Very nice result!
amazing idea, you should enter this into the shelving contest!
Thanks, I will do it!
