Introduction: Vision Shoe (Shoe for the Blind)
Hello, today we will be creating a shoe for the visually impaired. Such a device can make blind people blend in along with normal people and not make them stand out as when using a white cane. This can bring about significant improvement in confidence and quality of life of the visually impaired.
Step 1: Materials
Arduino UNO
Bread Board
Shoe (A cheap shoe from Walmart is perfect for this project)
Buzzer
Wires (You will need a lot for this project)
9V battery
Ultrasonic sensor- (Arduino hr-s04)
Push Button switch
220ohm resistor
Foam Board
Total cost= < $65
Step 2: Putting Together the Project
Two long wires are required for the buzzer because the buzzer will be going to the user's ear.
Step 3: Code
The code is attached- I based my code of Mert Arduino and Tech's code. ()
To check out his project visit the link below_________
https://www.youtube.com/watch?v=HynLoCtUVtU
Step 4: Building a Casing for the Hardware
Cut 2 rectangular 6-inch by 3-inch pieces from the foam board
Then cut 2 rectangular 3-inch by 1.5-inch pieces
Finally cut out a rectangular 6-inch by 1.5-inch piece ]
Before gluing, take the 6-inch by 3-inch side and score the box about 1.5- inches from the end of the 6-inch side make sure you go across the full 3 inches. Also, be careful that you don't cut the piece into 2
Glue the pieces together to create a rectangular box, Make sure the side that was cut on the 6-inch by 3-inch is placed on facing the inside of the box. (Look at example photos for reference)
After the box has been created cut a small square near the top of the box on the 3 inch by 1.5 inch for the wires to exit.
Step 5: Attaching the Box to the Shoe
To attach the box to the shoe I used glue, electric tape, and nails
First glue the box to the sole of the shoe
Then press half-inch nails from the inside of the box into the sole of the shoe (I used 6, but I think 2 should hold)
Finally, tape the box to the shoe
Step 6: Installing the Hardware
First tape the wires for the ultrasonic sensor to the tip of the shoe
Then depending on the type of wires you used either solder or place the ultrasonic sensor into the wires.
Then attach the push button switch to the bottom of the shoe
Finally, solder the buzzer to the two long wires.
(I added a plastic piece to hold the buzzer on the user's ear)
First Time Author Contest
Automation Contest 2017
9 Comments
3 years ago on Introduction
Can you tell me the code which has written by you is a aurdino or which language
4 years ago
Can it detect stairs? if not, how to add them?
5 years ago
u have a great creativity. your project is extraordinary. can u show how to make this using 3 ultrasonic sensor. please...
5 years ago
I wonder, could the box be placed on the hip and communicate with the sensors wirelessly?
Reply 5 years ago
i believe that the ultrasonic sensor and the arduino can communicate wirelessly
5 years ago
Awesome. It is like having another sense. I like it.
Reply 5 years ago
Thank you
5 years ago
I'll be adapting this for my blind dog, maybe making it lighter with an arduino nano
Reply 5 years ago
That is a great idea, I am really interested what that will look like. Please send me an image once you complete the project.
