WD40 Spray Holder Instruction Guide
Intro: WD40 Spray Holder Instruction Guide
The Fault
Lack of storage solutions available from factory options in commercial vehicles
Most commercial vehicles, van and camper conversions have limited storage solutions. They often come with the rear of the vehicle completely bare except from the MDF cladding on the inside of the shell.
Our Solution
Install X8R’s WD40 spray bottle storage bracket in under 5 minutes for a simple storage solution
X8R’s WD40 spray bottle holder is the perfect solution for tradespeople such as carpenters, electricians, plumbers, decorators, mobile mechanics and more. It can hold up to 4 bottles, with each hole having a cut-out for the straw mechanism on the tin.
The holder can be fitted with self-tapping screws for an easy installation (no power tools required, although you can use an electric drill if you wish) in under 5 minutes.
The bracket could also be wall-mounted such as in garages etc. Please ensure you use suitable wall plugs.
The bracket is made from 1.5mm thick black powder coated steel, a far superior material versus the inferior plastic other solutions which often break.
Compatibility
The bracket is compatible with the following:
- WD40 spray tins with or without straws
- Double TT spray tins with or without straws
- AC90 spray tins with or without straws
All other types of spray tins with or without straws as long as they have a diameter of 67mm or less.
You Will Receive
1 x WD40 spray tin holder in black powder coated steel
STEP 1:
Press the bracket against the wall you're fitting it to. Ensure it is level with a spirit level. Mark the holes with a pen.
Use an electric drill (or handheld screwdriver) to fit the bottom screws, and a handheld screwdriver for the top screws.
This completes the installation. If you need any further guidance on this install or would like to purchase the parts shown please call us on +44 01843 446643 or email us at sales@x8r.co.uk. Please also check out our instruction guide on YouTube. www.x8r.co.uk Installation is carried out at installers risk, if unsure please contact us or a professional, X8R Ltd cannot be held responsible for any adverse result of installing this product or any injuries caused by install, if in doubt ask a professional. All images and texts are copyright X8R Ltd 2024.
