Introduction: WII FIT SKATEBOARD
Mounting a skateboard on a WII FIT balance board
I thought the WIIFIT needed something so I mounted a skate board on it, so I made this plate/board it fits over the WIIFIT and is attached with Velcro all parts bought at Home Depot, I included the part#s, cost $20 - $30 give or take. I take no responsibility for your use of this construct.
THIS MOD WILL CHANGE THE CENTER OF GRAVITY OF THE WIIFIT AND IT IS POSSIBLE TO LOSE YOUR BALANCE, AND FALL OFF, SO USE CAUTION AND CLEAR THE AREA OF OBSTICLES.
I have been using this for about 2 days and writing this to so as to take a rest, have tried it with Shaun White Road Trip and it works well I think, tried it with Snowboard Riot seemed so-so but the controls are different, would like to see how it works with SKATEIT. I get WIISKI AND SNOWBOARD this week see how it works. I used it with Shaun White then took it off to see if there was a difference and without it the WIIFIT seemed to not respond as well, rather sedate
Step 1: Parts List
1 sheet 2x2 (24inX24in) � plywood cut to 24inX15in
Metal brackets from decking parts
4ea
4qty 8-10D X 1 �y 4-10D X 1/2
4qty GA2
2inch wide Velcro strips
�wide Velcro strips
#6 X � screws
Heavy duty felt pads
4ea
4qty GA2
�wide Velcro strips
#6 X � screws
Step 2:
START BY MARKING THE BOARD FIND THE CENTER POINT AND EXTEND YOUR MARKS TO THE EDGES, THESE MARKS WILL SERVE TO CENTER THE WIIFIT ON THE BOARD, LOOK AT THE TOP OF THE WIIFIT YOU WILL SEE IT IS INSCRIBED WITH A CROSS THAT EXTENDS TO THE UNDERSIDE PHOTO 1
Step 3:
APPLY A PIECE OF HEAVY DUTY FELT TO FLAT SIDE OF EACH OF THE GA2 BRACKETS
Step 4:
USING THE MARKS YOU MADE CENTER THE WIIFIT ON THE BOARD
Step 5:
ATTACH ONE GA2 TO THE CENTER EACH SIDE OF THREE SIDES OF THE WIIFIT, THE FOURTH SIDE IS THE SWITCH OFFSET THIS BRACKET SO IT DOES NOT INTERFERE WITH THE SWITCH, THE BRACKETS SHOULD HOLD THE WIIFIT SNUGLY PHOTO 2, 3, 4
Step 6:
Step 7:
Step 8:
TURN THE BOARD OVER
Step 9:
CENTER THE SKATEBOARD ON THE BOARD
Step 10:
MEASUREMENTS HERE VARY
REFER TO THE PHOTOS FOR PLACEMENT OF BRACKETS ONE 8-10 1 �ND ONE 4-10D � 2 INCH VELCRO TO HOLD THE BOARD IN PLACE
PHOTOS 5,6,7,8,9,10
PHOTOS 5,6,7,8,9,10
Step 11:
Step 12:
Step 13:
Step 14:
Step 15:
USE �PS OF VELCRO TO ATTACH THE BOARD TO THE WIIFIT, PHOTO11
Step 16:
THIS MOD WILL CHANGE THE CENTER OF GRAVITY OF THE WIIFIT AND IT IS POSSIBLE TO LOSE YOUR BALANCE, SO USE CAUTION AND CLEAR THE AREA OF OBSTICLES.
I HAVE TRIED THIS WITH SHAUN WHITE ROADTRIP AND IT SEEMS TO WORK WELL, YOU MAY HAVE TO TIGHTEN YOUR TRUCKS SOME, WOULD LIKE TO SEE HOW IT WORKS WITH SKATE IT.
