Introduction: Wall Mount IKEA SUNNAN
The IKEA SUNNAN is a great Solar powered desk Lamp, but lacks an important feature:
WALL MOUNT
But this can be solved in some easy Steps.
Step 1: Open the Lamp and Remove the Weights.
Open the Lamp and remove the weights.
Step 2: Make Cut-outs to Remove the Solarpannel While Wallmounted
As the Lamp is built for desk usage, the Solarpannel/Battery unit cannot be removed for charging if the Lamp is mounted on a wall, thats why we cut out the case.
Mark the cout-out between the middle an the side with the battery contacts, so there is nothing in the way.
Use a Dremmel, Jigsaw, sahrp solid cutter or whatever you have at hand.
Step 3: Mount the SUNNAN to a Wall
Now you can mount the SUNNAN to a wall, put the screws to fix it to the wall in the cut-outs just made, or use some double-sided tape.
