Wallet Sized Photo Frame Altoids Kit
Introduction: Wallet Sized Photo Frame Altoids Kit
These steps will guide you through to make a wallet sized photo frame that will fir in an Altoids can when in parts. The finished, assembled product should look similar to this.
Step 1: Make the Front of Body
Create the front of the body. I put 1/4 inch holes at the corners and left enough space to cover the edges of the photo. This one is 3 inches tall and about 2 inches wide, all while being around .115 inches thick.
Step 2: Make Back of Frame
The back of the frame should have the same height, width, and thickness. Also it should have 4 rectangles on it, for the stands to fit through. My rectangles are .5 inch in height and .115 inches wide, and vertically 2 inches apart.
Step 3: Make Two Stands
I made two stands, .115 inches thick, and 2 inches high. I made the angle a little under 90 degrees.
Lastly, make four .25 inch diameter studs to hold the parts together.
Either in an Altoids can, or assembled on your desk, your photo frame is ready to go!
Be the First to Share
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
