Wardrobe on Tension.
Intro: Wardrobe on Tension.
I needed a wardrobe, but I didn't like large boxes.
So I decided to make a wardrobe on carrier cables.
STEP 1:
You can buy all the materials in a hardware store.
You will need:
Cable (2 identical segment)
hooks (4 pcs)
anchors or dowels (for attaching hooks to the ceiling and floor)
lanyards (2 pieces)
electrical terminal blocks for what would make stops
Steel crossbars
Tools:
drill
screwdriver
knife
measuring ruler and tape
wrench
You will need:
hooks (4 pcs)
lanyards (2 pieces)
Steel crossbars
Tools:
drill
screwdriver
knife
wrench
STEP 2:
First, you should measure the distances between the hooks you are fixing to the ceiling and the floor. The hooks in the ceiling should be placed symmetrically to the hooks in the floor. Make cable-diameter holes next to all four corners of each shelf as well as on the ends of the crossbar. Then put the construct together step-by-step by stringing its parts on the cable and fixing them with contact terminals with even spaces between elements. I used contact terminals from the terminal block because I couldn't find anything else that would work as good.
STEP 3:
When the construct is ready, hang it on the hooks. In order to strain it, you can use lanyards. After the construct has been fixed on the hooks, you can regulate the levels if it is necessary. Finally, stretch the construct out with lanyards.
STEP 4:
It’s very simple and can be made by intuition. I didn’t try to stick to certain measurements in the process of work.
STEP 5:
I hope you'll find this useful.
9 Comments
naasim 11 years ago
bwelkin 11 years ago
etranqer 11 years ago
dandroid20xx 11 years ago
Katzsta 11 years ago
chuckyd 11 years ago
Of course, if you live in an area with seismic activitiy, plan on picking up your clothes every time there is a tremor.
By the way, the cable idea has been around for some time, and there are companies that specialize in such material and have a complete line of anchors, connectors, etc. that really look cool.
zanne101 11 years ago
Can you move the hanger bar up a little? Looks like some wasted space there when looking at it with your clothes included.
Or maybe you can attach the bar to the underside of the top shelf with some kind of J shaped bracket?
Nice work.
mganpate 11 years ago
Penolopy Bulnick 11 years ago
