Introduction: Water Bottle Mouse Trap
This is my first instruct able hope you enjoy
Step 1: Materials
Water bottle
2 rubber bands
2 sticks of some sort (I used blow gun darts)
Knife (box cutter works the best)
Multi tool
Step 2: Starting to Cut
Cut open the bottle where I'm cutting it open at
Step 3: Poke Holes
Poke holes where I'm doing it at ( I'm just doing it with the blow gun darts) but if that's not what your using you can use a needle
Step 4: Putting the Sticks and Rubber Bands On
You insert the sticks you are using into the holes you just poked and then you slide the rubber bands on either side then slide the rubber bands all the way tell they touch the water bottle
Step 5: Make the Trigger
First you get a pice of string( I used one of the inside strands of 550 cord) then u screw one end of the string into the cap and then tie a slip not in the other then you take a paper clip and bend it like I did
Step 6: Setting the Trap
You take the paper clip and use the plier end of the multi tule to put the paper clip into the hole you poked at the back end of the water bottle then take the string and the slip not that you tied and slide it over the paper clip and it is set and that's the end please vote for me
First Time Author Challenge
4 Discussions
5 years ago
I agree the Instructible isn't complete. Shouldn't have to go look it up on the internet to find out how something works. I grade this a D.
6 years ago on Introduction
how does it work???
6 years ago
Just lookup water bottle mousetrap on YouTube there is a lot of videos on YouTube about it
I would like to see a video of this in action.
