Water Conservation Cludge
Intro: Water Conservation Cludge
easy to build, purely mechanical version of a sensor activated sink. Could I make a sensor activated sink? yeah no problem, but this was more fun to think up, will be easier for the average person to make, and doesn't involve a) putting high current electricity near water or b) electrically actuated valves which need cleaning (microbe build up).
All you need is to
a) hook up a hose to your sink spout
b) run the hose to the floor where you pass it through the jaws of a strong spring clamp
c) run the hose back up to the sink head (or wherever you wan to send the water)
the most annoying part is adapting a hose to your sink spout. If done incorrectly water will leak out at the junction. As long as the leak isn't much you're still conserving water but try to make the adapter as tight a fit as possible. The tips of many sink spouts unscrew, so you could maybe but a properly threaded adapter somewhere but I just used hot glue (see the glue gun in the video) and the cap of a contact lens cleaner to make a pretty good adapter.
Update 2013:
Here are some supplies that you could use to build the system in a reliable non-leak way:
1) short garden hose with rubber gasket (get two) (see: http://www.amazon.com/American-Specialty-UT-10-Multi-Purpose-Utility/dp/B000T2B468/ref=sr_1_14?ie=UTF8&qid=1378139332&sr=8-14&keywords=Short+Garden+Hose)
2) Garden hose-to-sink adapter (as described here: http://www.wikihow.com/Attach-a-Garden-Hose-to-a-Kitchen-Faucet)
3) Garden hose foot pedal (as shown here: http://www.amazon.com/Nelson-Yardworks-Water-Pedal-Control/dp/B002URLTXS)
best of luck!
All you need is to
Update 2013:
best of luck!
8 Comments
rexdino5 14 years ago
leevonk 14 years ago
Thanks!
leevonk 10 years ago
BluTiger 10 years ago
Here's links to supplies that you can use to build the system in a reliable non-leak way:
1) Garden hose-to-sink adapter (as described here: http://www.wikihow.com/Attach-a-Garden-Hose-to-a-Kitchen-Faucet)
2) Garden hose foot pedal (as shown here: http://www.amazon.com/Nelson-Yardworks-Water-Pedal-Control/dp/B002URLTXS)
3)
best of luck!
