Introduction: Ways to Make Fire Hacks in Minecraft
As a haven't posted a instructable in a long time this is a special minecraft fire hack on minecraft it's really easy and cool! Have you ever wanted to light tnt without it exploding, Or make invisible fire or make floating invisible fire?!?
Flint and steel/any fire item ,tnt(optional), any block, (make sure fire spreads is off), (tnt explodes can be on), (this is a glitch so do it while you can mojang may remove it )
Step 1: Invisible Fire
To make invisible fire you want to take you oak stripped logs and place them where you want your invisible fire it can be floating next light the logs on fire on the top, sides, or bottom next destroy the logs and you get invisible fire test it out by walking or flying into where you destroyed your logs and your character should be on fire and if you put the blocks where you put the fire it should light on fire exactly when you place it!
Step 2: On Fire Tnt
To do this you need to do the same invisible fire trick and then one simple step place the tnt on the invisible fire then the tnt should not explode
Step 3: How I Made This
I was looking for hacks to show you then I gave up to take a break on minecraft then the next thing I know is i'm playing with fire literally then I just got this trick
