Introduction: Wedding Style - Floral Bun
Floral bun style for weddings, or any other special event!
Step 1: Materials
❧ Brush
❧ Clips
❧ Comb(s)
❧ Hair ties
❧ Small rubber bands
❧ Pin curl clips (or small clips with a tapered end)
❧ Bobby pins
❧ Hairspray
❧ Optional: decorations for hair (i.e. twist-in gems, flowers, decorative pins, etc.)
Step 2: Partings & Ponytail
❧ Part the hair into 4 sections
❧ Section by section, part out the perimeter of the hair (approximately 1 inch from the hairline)
❧ Clip the perimeter pieces out of the way
❧ Take out the four sections and smooth the hair into a ponytail, keeping the perimeter separate
Step 3: Perimeter Curls & Ponytail Parts
❧ Curl the hair in the perimeter, pinning each curl in place while it cools
❧ Take a center piece from the ponytail, clipping away the hair around it
❧ Rubber band the center piece
Step 4: Floral Bun
❧ Take the center piece of the ponytail and create a rope braid
❧ Twist the braid into a bun shape, pinning it in place as you go
❧ Separate the rest of the ponytail hair into 3-4 sections
❧ Braid each section and "pancake" one side of each braid ("pancaking" refers to fanning out pieces of a braid), rubber banding the ends
❧ Wrap each braid individually around the rope braid bun, pinning in place as you go
❧ Make sure all ends are tucked in
Step 5: Curls
❧ Take the perimeter curls out one by one, combing them smooth
❧ Smooth them towards the bun, pinning them beneath the "petals" (these can be placed anywhere around the bun; I chose to put them all on one side for an asymmetrical look)
❧ Take your pin curl clips and gently pin the ends of the curls out, hairspraying them lightly
❧ Do this for every curl
Step 6: Finish!
❧ Once all of the curls have been pinned & hairsprayed, carefully remove the clips and position your curly ends where you want them
❧ Hairspray them again & hairspray the rest of the style, smoothing any flyaways
❧ Optional: Add hair decorations where you see fit
❧ Finished!
Runner Up in the
Hair Contest 2016
4 Comments
6 years ago
Wow, this is very beautiful! But I probably myself won't be able to do so)
Reply 6 years ago
It's actually very easy ! It's just looks complicated haha
6 years ago
This looks really good. Good luck in the hair style contest.
Reply 6 years ago
Thanks !!
