Week 1: Laser Cut Ornamental Pattern (MAT238)
Intro: Week 1: Laser Cut Ornamental Pattern (MAT238)
In this project, I designed a randomized circular pattern in Grasshopper, performed post-processing in Adobe Illustrator, and laser-cut the final design in cardboard.
STEP 1: Stock Dimension Setup
I first created nodes to control the dimensions of the stock. These dimensions are used later to scale the design to fit on any sized stock. This section seems more complicated than it really is due to the use of math operations.
STEP 2: Randomized NURBS Generation
To generate the base curve for my circular pattern, I used the Populate 2D node to generate a list of random points in a specified rectangle with the first and last points being on opposing corners of the rectangle. This list of points is input into the NURBS node to create the random curve.
STEP 3: Circular Pattern
To repeat the curve in a circular pattern, I wrote a Python node that inputs the number of curves and stock size and outputs the pattern. I also experimented with having multiple concentric circular patterns, but I found that it overcomplicated the design, so I just stuck with one. The offset node gives the curves a thickness so it can be laser cut.
STEP 4: Cleanup in Illustrator
I used the Shape Builder tool in Illustrator to clean up the design and remove unwanted intersecting lines. I also added an outer circle to cut out the pattern from the stock.
STEP 5: Laser Cutting
The design was formatted for the laser cutter and the cut was completed in under a minute :)
2 Comments
marcelrr 7 weeks ago
This looks great! I'm glad that the Python node is there to make simple tasks that would otherwise be complex to achieve with the available nodes.
schattoraj 7 weeks ago
I enjoy that you randomized your circular pattern since it allows you to potentially experiment with different designs. I am curious if you kept randomly generating designs at all once you decided to use one concentric circle pattern before you settled on your final one.
