Introduction: Weller Baterry Powered Soldering Iron
I have this battery powered soldering iron from Canadian tire made by Weller and the power switch is the type where u have to hold, on top of that if u don't hold it in the exact right position it wont stay on. This is really annoying so I did something about it. I am not responsible for any harm you cause to yourself, others or any damage you cause while attempting this instructable.
Step 1: Materials
-Soldering iron
-Knife
-Wire strippers
Step 2: Dissasemble
So start by removing all the screws, there are three check under the sticker that's where two of them are.
Step 3: Switch
Now remove the little black part of the button with a knife simply cut it off and it will pop out then make the hole in the red part big enough to accommodate you're new switch in my case a toggle switch.
Step 4: Wire in New Switch
Now solder wires to the old battery leads going to you're new switch.
Step 5: Close It Up
Close it up and you're done go test out you're new less annoying battery powered soldering iron.
