Weller Baterry Powered Soldering Iron
Intro: Weller Baterry Powered Soldering Iron
I have this battery powered soldering iron from Canadian tire made by Weller and the power switch is the type where u have to hold, on top of that if u don't hold it in the exact right position it wont stay on. This is really annoying so I did something about it. I am not responsible for any harm you cause to yourself, others or any damage you cause while attempting this instructable.
STEP 1: Materials
-Soldering iron
-Knife
-Wire strippers
-Knife
-Wire strippers
STEP 2: Dissasemble
So start by removing all the screws, there are three check under the sticker that's where two of them are.
STEP 3: Switch
Now remove the little black part of the button with a knife simply cut it off and it will pop out then make the hole in the red part big enough to accommodate you're new switch in my case a toggle switch.
STEP 4: Wire in New Switch
Now solder wires to the old battery leads going to you're new switch.
STEP 5: Close It Up
Close it up and you're done go test out you're new less annoying battery powered soldering iron.
10 Comments
Dingleburg96 8 years ago
turbiny 9 years ago
nice fix for the problem but never leave it with batteries in its way to easy turn it on accidently while moving it around.
Adam Manick 12 years ago
https://www.instructables.com/id/Make-a-battery-powered-soldering-iron/
mdog93 12 years ago
chris.t.r 12 years ago
mdog93 12 years ago
mdog93 12 years ago
