Introduction: Game for the Car
Cardboard
Box , small box , 2 pens and
Wax gun
Step 1: Where Do I Get a Motor?
You can get the motor from a portable vacuum cleaner and all the parts will be present in it, and you do not have to solder the wires
Step 2: Box Sizes
The length should be approximately 15 cm, the width should be approximately 10 cm, and the height should be approximately 3 cm
Step 3: Put the Engine in the Pen
The pen tip must be placed on the pen, after which the motor head is inserted into the front pen hole, then glued from the back end, and then the pen is placed in it
Step 4: Put the Engine in the Box
The box should have four openings, every two facing each other, and the hole should be the size of a pen
Step 5: The End
You can put the motor inside the small case and glue the start button into it. This is not necessary
Step 6: Notice
إضافات جديدة: لقد قمت اليوم بإضافة إضافات للعبة حتى أجعلها تعمل بالشكل المطلوب
Step 7: The Map
You should bring a sheet of 29.5 cm long
Step 8: Drawing on the Map
Now we'll draw on the map
You can draw whatever you want, but I will paint cars on the street
I drew cars about 3 cm long
And I colored it, don't be blamed because my paper is a little bad
Step 9: Thread and Car
Now I'm going to draw a car on a piece of paper and then cut the car out of the paper
Then I will bring a white thread (preferably a street color) Then I will punch two holes horizontally in the box, from each end a hole parallel to the other Then, insert the thread from the two holes, making sure that it does not enter the entire thread, then bring a piece of adhesive And stick it under the thread and place the car image on the thread You will be stuck on the thread from
Step 10: Paste the Map
Get a sticker and tape the end of the paper to the other end
Until it becomes like the one in the picture
Step 11: Put the Map in the Box
عليك أن تضع الخريطة داخل الصندوق
أولاً: ضع الخريطة داخل الصندوق
ثانياً: إدخال قلم من إحدى الفتحات
ثالثًا: اسحب الخريطة إلى الفتحة الكبيرة الفارغة وضع قلم المحرك بداخلها
تهانينا ، لديك لعبة سيارات !!
Toys & Games Contest
