What You Never Knew About Doing the Dishes With a Sponge
Intro: What You Never Knew About Doing the Dishes With a Sponge
After living with college roommates that couldn't seem to do the dishes properly, I realized I had to get the word out there about proper dishwashing duty.
STEP 1: Dishsoap and Sponges
The first thing to realize is that dishwashing is not about sanitizing (killing the bacteria and viruses on) your dishes. If you look on your dishsoap (any brand will do), you will notice that it does not claim to "disinfect" your dishes!
What is the point of dishwashing?
To remove food, scum, scents, flavors, grease, oil, etc. from your dishes.
What is the best tool to use?
Use a sponge that has a scrubby side on it. This way you can soak up soapy water to scrub away at your dishes with. Using a plain sponge with no scrub is pointless - it won't scrub the food or grease off of your dishes!
How do I get rid of the "germs?"
Washing your dishes will help get rid of most of them, and the rest tend to die once the dishes dry off (bacteria can't live without water!). However, if you're concerned, you could always rinse your dishes with a 1/20 bleach dilution, or add a tiny bit of bleach to your dishsoap.
STEP 2: Soak Your Dishes and Silverware
To make it easier to wash your dirty dishes, soak them in hot water for a while! If you have food dried onto your dishes (mashed potatoes, pancake mix, baking residue) or sticky, gunky stuff (peanut butter, grease), soaking them for a while will make it MUCH easier to scrub the stuff of. You will be spending way less time on it.
STEP 3: Two Methods for Soaping
If you have a lot of dishes, the best thing to do is fill a bowl up with very hot, very soapy water. You can dunk your sponge into this bowl whenever it needs more soap.
If you don't have as many dishes, or if you're feeling lazy, squirt a little soap onto one side of your sponge (the scrubby side) and run a little of hot water onto it.
STEP 4: Scrub Those Dishes!
While doing your dishes, keep your sponge separated into two sides: the YUCKY side, and the SOAPY side. Use the yucky side to wipe off particularly grimy dishes. After getting the heavy grime/food off, then use the cleaner, soapier side to get it really clean.
Make sure you wash the outside and bottoms of your dishes, especially the ones you stack. Nobody wants a cup with grimy fingerprints / lip prints on the outside, and if you leave food on the bottom of your bowls or plates, it will transfer onto the top of the bowl or plate underneath it!
When washing silverware, don't just wash the end of it - wash the entire length of it. This way, no matter how you leave them to dry, the entire thing will stay clean and germ-free-ish.
STEP 5: Rinse and Stack
Rinse your dishes off! Hot water is recommended because it carries the soap (and grease, oil, etc.) off of the dish more easily than cold water.
When stacking your dishes to dry, make sure you stack them upside-down, so that water can run off of them and not collect inside.
STEP 6: Care for Your Sponge: Important!
You know that stinky smell your sponge gets after a couple of weeks? BACTERIA!!
Sponges are a haven for all sorts of bacteria. They LOVE growing in there! It's important to make sure your sponge is bacteria-free if you are cleaning things like cutting boards and countertops (not to mention anything else).
How to keep your sponge clean:
1. After doing the dishes, rinse your sponge thoroughly in hot, and then cold, water, squeeze out as much water as possible, and set it outside of the sink (near your soap bottle, perhaps).
2. Never leave your sponge in the sink or in water.
How to clean your sponge once it's filthy:
1. Saturate it with cold water and then microwave it for 1 minute. DO NOT TOUCH! It will be EXTREMELY hot!
or:
2. Soak in a bowl of 1/10 bleach to water solution for 10-20 minutes.
or:
3. Soak in a bowl of 1/5 vinegar to water solution for 10-20 minutes.
or:
or:
29 Comments
Katie5757 12 years ago
JessicaM297 7 years ago
how dies using a dish brush vs a sponge mean the water will be hotter vs cooler?
Katie5757 7 years ago
You can use very hot water and not burn your hands.. High temperature kills off the bacteria together with the dish detergent.
Rinsing with bleach, I dont know. There are health department guidelines for commercial kitchens which are about temperature of water. Many are phobic about using bleach, including for cleaning. I use it often.
Most, including commercial kitchens, involve dishwashers. However, I dont know what the those temperatures are...Hotter than hand dishwashing temps.
Anomy 9 years ago
Katie wrote: "ummmm. adding bleach to detergent I believe creates a chemical reaction which is not healthy"
Definately true with amonia, and my take on mixing cleansers and such is: Isn't worth the risk.
rfraser2 10 years ago
aboddy 12 years ago
GoddessFourWinds 11 years ago
DIY-Guy 12 years ago
Bleach and ammonia, or bleach and toilet cleaner (lye types) does make toxic gasses similar to those used in World War One. The chlorine in bleach needs a strong reagent to form chlorine gas, not detergent.
Detergent is fairly innocus stuff. A little bleach is a good idea for sterilization, but don't over do it.
Happy dishwashing to you!
pjds78 11 years ago
I 'm sorry but it isn't a myth about the danger of bleach with SOME dish-soap. I myself had the misfortune of using bleach with Dawn Dish-soap. It took my breath away. I nearly passed out before I pulled the plug to empty the sink and then I ran out of the house. You can use bleach with Laundry Detergent, but not with all Dish-soaps. There is even a case in California back in the 70s of a woman who died from the toxic fumes. We have to be very careful and read the caution on each brand to know when it is safe to use.
We can avoid the whole thing and have a tub of rinse water handy and put a teaspoon of bleach in that just to be safe.
AnthiN 8 years ago
vincent7520 10 years ago
When my sponge becomes somewhat foul, I discard it for dishwashing and use it for cleaning such dirty things as small spots on floor etc. Then I take it to my boat where it will end its life in dirtier, gooey matters such as the engine hold …
somedudeonline 10 years ago
Ok, instead of using bleach or getting the sponge smell on your dishes after you microwave the sponge. Do what I do. This can really be a pain if you wash all of your dishes by hand but if you just wash certain things by hand and leave the rest to the dishwasher then it's not too bad.
So, do something similar to what this article says with the sponge. Get the gunk off then wipe with soapy sponge, rinse with warm water, then wash your hands with your dishsoap and drizzle some dishsoap on the dish, then use your hand to spread the dishsoap to every surface of the dish, rinse with warm water again until you can feel that you've removed all of the dishsoap, then rinse with the hottest water that will come out of your tap.
Hugandkisses 10 years ago
Katie5757 10 years ago
Use hot hot water, use dish brush. Rinse all your dishes in at least warm water immediately after use.. otherwise you need to chisel off the gunk. My mother used to say..soak to the hilt and this means pots and pans. You will be washing dishes in very dirty.
rfraser... soak them first and you likely wont need to scrub. I think the instructable was about humans and not for kennels. Animal hygiene is very different to human hygiene standards.
My brother made the comment that it is better to remove the offending articles from insects who further contaminate uncleaned dishes sitting around the kitchen, and of course uncleaned counters, and the cleaner of such containers.
ckoehler1904 12 years ago
22tpring 12 years ago
lcrayzee 12 years ago
TireDog1 12 years ago
tran_s 12 years ago
Kayla Ree 13 years ago
