Introduction: What to Do With Open, Half Used Caulk Tubes
We all have open tubes of caulk which sit and dry out. So what is a person to do about it?
Step 1:
Using a flatblade screwdriver, scrape out about last inch of opening.
Step 2:
Using a q-tip, wipe inside clean.
Step 3:
Using a hot glue gun, fill inside with glue and make it slightly overflowing.
Step 4:
While glue is slightly cooled, but still soft, mushroom out the top. Let glue harden and you have an airtight seal to your caulk tube. No more waste.
4 Comments
6 years ago on Introduction
Update, I pulled the hot glue plug out of the above tube of caulk tonight because I needed to seal up an outdoor light. Still is good 2 years later.
8 years ago on Introduction
Good tip. Better than plugging it with a tapered dowel. As I used to do until I saw this tip! One point though, are there no adverse chemical reactions between the hot glue & the Caulk / sealant, etc?
Not to my knowledge. Beats the old screws I used to use.
Reply 7 years ago
wirenuts also can work. twist overopen end. they come in different sizes and sometimes it helps to have a little caulk coming out to help secure it.
