What's Inside? #1: USB Phone Charger (Salvaging Electronic Components)!
Intro: What's Inside? #1: USB Phone Charger (Salvaging Electronic Components)!
This Is a 5.0 Volt 0.7 AMP Samsung phone charger
STEP 1: Tools
These are the tools I used If you take one apart you may need to use different tools:
Wire Cutters
Pliers
Flat Screwdiver
STEP 2: The Parts
2 Resistors
2 400V 4.7 Micro-Farads Electrolytic Capacitor
50V 470Micro-Farads Electrolytic Capacitor
Useless connector (for me)
And a useless transformer because I couldn't find the datasheet so I don't know what it does.
I had a couple a problems with the capacitors so I'm not really happy of this overall, but, hopefully I'll do more of these "Whats Inside" Instructables which will be better.
Does anyone know if the is voltage converted from AC to DC with the capacitors? I am asking this because there is no bridge rectifier (diode bridge).
Do you like taking apart electronic devices? I've made a collection of a couple"What's Insides" If you're interested:
7 Comments
sasukefan9tails 3 years ago
Yonatan24 3 years ago
Raphango 8 years ago
i think the transformer outputs te specified voltage (5V) and the Caps just do the "buffering"/filtering job.
Maybe theres' a couple diodes under the transformer to make the AC-DC conversion.
PeterA14 8 years ago
I am a Little confused - You say 2 Resistors and 4 Capacitors only which look to be Electrolytic's (Polarity Conscious).
You do not say what E10 JH1415 is, which I am assuming is the Transformer. It would be bad design, and I have never heard of the use of electrolytic capacitors to rectify a.c. and all the components look correct for a charger unit. There has to be a d.c. source feeding the Capacitors whether it be a simple diode or a bridge rectifier. I suspect on closer examination of E10 JH1415 you will find your answer. another solution would be to redraw the circuit from the PCB tracks to gain an idea how it is wired
Yonatan24 8 years ago
I already threw the transformer a couple days ago into the trash so I can't do that, And yes, I'm also confused
dbyrd26 8 years ago
That could be true, Next time I take one of these apart I'll open the transformer and check
