Where's My Desoldering Iron!?
17,869
30
57
Introduction: Where's My Desoldering Iron!?
Need to do a little desoldering and don't have (can't find) an iron?
The purpose of this instructable is to show how you can remove solder from a board when you're in a pinch.
Let me know what you think of doing it this way or if you have another method...
Step 1: First Things First
Here's what you'll need:
1) Something you want to desolder
2) a piece of wire or two
3) tinning flux would be nice
4) a soldering iron
5) wire strippers
6) pliers
I'm using a strand from a piece of cat 6 cable I had laying around. All I had was solid, but I'm guessing the stranded type might work even better (like copper braid).
Strip the wire back a couple of inches and get out those pliers.
Step 2: Bend the Copper to Your Will. It Will Do Your Bidding.
Start with a small bend and go from there.
Be sure to leave the bend kind of open. You want a little wicking action going on (or is this capillary effect?) to get that solder away from the board.
Step 3: Tin It Up. Suck It Up.
Put a little flux on your wire like you are going to tin it.
Press the shaped wire down on the solder to remove and press the soldering iron on top of that. You are basically making a copper sandwich with the board on one side and the soldering iron on the other.
Sorry about no pics for this part. This took both hands and I'm a little clumsy with a camera in my mouth. (excuses excuses)
Oh yeah, be sure you hold the wire at least three or four inches back. As it is copper, it can heat up a little quick. If it heats up too much though, you are probably keeping the heat on it for too long!
If there is still solder on the board, just snip your wire back and do it again.
Step 4: Just Like New.
And there you have it!
After a press or two, the solder has cleared off the board and out of the component hole.
Be the First to Share
    • Clocks Speed Challenge
    • Toys & Games Contest
    • Big vs Small Challenge
    57 Comments
    whatup.dub
    whatup.dub
    Reply 8 years ago on Step 4
    Why, yes it is an easy button board.
    mrmerino
    mrmerino
    9 years ago on Introduction
    Buy a desoldering braid? Or a desoldering pump? One of those with the big plunger and the spring. Those springs are strong. My tongue still hurts.
    putty1cat
    putty1cat
    Good idea! I will have to try this on those really old mobos, that the solder never seems to heat and melt. I really want the capacitors for a batteryless torch.
    jtc10512
    jtc10512
    10 years ago on Step 4
    Very nice. I've wanted to do this when i need parts off of boards. sometimes, when i cant heat it up, i even bend the pins off. (not a good idea) i used to wonder what a good way to absorb solder was. there's copper braids that you can buy, but this is a good and cheap alternative.
    pgd5000
    pgd5000
    10 years ago on Step 2
    thanks, love the matrix reference
    fallenspirit123
    Hey i have always wondered... are those weller cordless soldering irons any good?(unlike coldheat)
    raykholo
    raykholo
    Reply 11 years ago on Introduction
    DO NOT USE COLDHEAT! it can potentially damage ur components and is not a good tool to work with pcbs
    im guessing that u mean the weller butane irons. The portasol is said to be pretty good and i am considering getting it.... not only is it good for soldering (using a soldering tip) but the hot air tip and blow torch tip can be used for smt work and also possibly desoldering... Adjustable flame control also allows for precision temperatures as to not burn out certain components such as semiconductors, which are very heat sensitive
    Clearly, i have done my homework on this topic, so to say
    these are the irons i am talking about
    raykholo
    raykholo
    no prob so were u talking about the butane irons? cuz they also have battery powered ones which i dont think are good though....
    agis68
    agis68
    Reply 12 years ago on Introduction
    excellent if u do tiny jobs due to very thin soldering edge. Beautiful for detail jobs. And the batteries last long. Just remember to use 60/40 solder. Not less!!!
    pyro man
    pyro man
    duh they're weller arent they?
    pyro man
    pyro man
    ur stirppers are on the way!!!
