Where to Find LED Lights... (Not in Shops)
Intro: Where to Find LED Lights... (Not in Shops)
This is my first instructible so please go easy on the comments, thanks.
In this instructible i will show you where to find LED Lights...
(not in shops)
Please Rate And Comment this Instructible...
(not in shops)
STEP 1: Finding LED's...
Dunno Wat To write, by the way just to say, throughout the steps i will just put pictures on, just to show u where u can get leds....
keyboards Have LED Lights !!!
119 Comments
Yonatan24 8 years ago
Lavoz24 7 years ago
you are correct! I was about to comment but I read yours. Also, remotes have surface mounted LEDs but they are so tiny at times it's not worth trying to remove them.
avenger09123 13 years ago
wsni 13 years ago
He'd leave me alone for a while, at least until he forgot how much it hurt.
My dad to do that as a kid, With a 300V Electrolytic Capacitor!
lsmith254 11 years ago
ginger20037 12 years ago
You are the Payback Master! :D
ElectroFrank 9 years ago
Ebay has 100 white 5mm LEDs for £1.15, 100 assorted LEDs for £1.75 (yes, all the way from China).
Still, right from my childhood I learned a lot from taking things apart.
Sometimes I even got them back together again.
astral_mage 10 years ago
tezzachs 13 years ago
SugarCluster 10 years ago
(make one by wrapping whole bunch of insulation tape on one end of it)
Flip the TV and remove the case.(wear rubber gloves if you don't want to be like me)
Now it's time to use that metal rod,just poke around until you hear loud bang.
Don't worry,it's now discharged.
(if you just want to get LED from it,not scrapping it,find a big capacitor and touch both leads with insulated metal rod from above)
Or if that TV is broken,just throw that into water. It will discharge whatever is on the TV,making it safer to work on.
zenderon 13 years ago
Discharge the metal end to ground just incase it's charged
You need 2 screwdrivers with insulated handles make sure you DO NOT touch the blades place 1st tip on the aquadag..the silvery/black stuff sprayed on the back of the tube 2nd screwdriver blade onto the blade of the 1st and touch the crt topcap on the tube if charged you should get a healthy spark 5 to 10mm long. do this a few times over a minuite or two to be on the safe side seeing that your new to it
REMEMBER THIS IS A CAPACITOR AND WILL RECHARGE UNTILL FLAT
Hope this helps you Rog
ivaneduardo747 13 years ago
ppanchal1 10 years ago
instme344 11 years ago
nerj 12 years ago
pj63 12 years ago
abcmax 12 years ago
