Wifi for Weather Station WS2357 Lacrosse
Intro: Wifi for Weather Station WS2357 Lacrosse
Use of the module ESP8266 with a meteo station LACROSSE WS2357
STEP 1: PART
Here is a realization a meteo station ws2357 in WiFi with the module ESP8266 to realize this assembly
it is necessary:
ESP8266 : 3.49 €
http://www.banggood.com/Upgraded-Version-1M-Flash-...
Power converter : 1.75 €
http://www.banggood.com/Mini-DC-DC-Converter-Step-...
USB converter FTDI : 3.12 €
http://www.banggood.com/buy/ftdi-serial-adapter
LM317 : 4.10 €
MAX 232 : 2.50 €
ICL7660 : 3.50 €
STEP 2: SUPPLY 6V
Realize a supply 6v with the regulator lm317
STEP 3: NEGATIVE -6V
Realize a negative tension of -6v with the circuit icl7660
STEP 4: CONNECT RS232 and ESP8266
Realized a converter rs232 ttl and to DB9 connector Pin 2, 3, and 5
On pin 11 and 12 connect the WiFi transmitter ESP8266 with a resistance of 1k ohm
The working unit has DTR as -6v and RTS at +6v
to other realize
http://www.kiblerelectronics.com/corner/ccii_12.ht...
STEP 5: UPGRADE ESP8266
Adjust the converter dcdc 6v to 3.3v
Link the module esp8266 with a FTDI
upgrade the Firmware of the module in LUA language
Look
https://github.com/nodemcu/nodemcu-flasher
http://randomnerdtutorials.com/home-automation-usi...
http://www.xess.com/blog/esp8266-reflash
http://www.allaboutcircuits.com/projects/update-th...
Program with ESPlorer the module with the code init.lua and bridge.lua to realize a serial bridge tcp / ip
Look
https://github.com/4refr0nt/ESPlorer
https://github.com/nodemcu/nodemcu-firmware
http://www.esp8266.com/viewtopic.php?f=24&t=4152
-- init.lua
abort = false
wifi.setmode(wifi.STATION)
--modify according your wireless router settings
wifi.sta.config("SSID","PWS")
wifi.sta.connect()
function startup()
tmr.stop(2)
if abort == true then
print('startup aborted')
return
end
uart.setup(0, 9600, 8, 0, 1, 1)
dofile("bridge.lua")
end
abort = false
tmr.alarm(1, 1000, 1, function()
if wifi.sta.getip()== nil then
print("IP unavailable, Waiting...")
else
tmr.stop(1)
print("Config done, IP is "..wifi.sta.getip())
tmr.alarm(2, 5000, 0, startup)
end
end)
-- Bridge.lua
-- Based loosely on code by Thorsten von Eicken, esp8266-lua-bridge , (C) 2015
uartConn = nil -- current connection that uart input goes to
ser2net = net.createServer(net.TCP, 28800)
ser2net:listen(23, function(conn)
if uartConn then
uartConn:close()
else
uartConn = conn
end
conn:on("sent",function(conn)
collectgarbage()
end)
-- Disconnection
conn:on("disconnection", function(conn)
uartConn:close()
collectgarbage()
end)
-- Reconnection
conn:on("reconnection", function(conn)
if uartConn then
uartConn:close()
else
uartConn = conn
end
end)
-- UART receive, TCP send
uart.on("data", 0, function(data)
conn:send(data)
end, 0)
-- TCP receive, UART send
conn:on("receive", function(conn, data)
uart.write(0, data)
end)
end)
STEP 6: ENJOY
Download the software USR-VCOM virtual serial converter
http://www.tcp232.net/com-net-software
Download the sofware to weather station SkinWS2800 and other
http://schnellbach.pagesperso-orange.fr/PageSkinTe...
Enjoy
STEP 7: ASSEMBLY
Assemble the circuits on a plate
GayathriP2 7 years ago
I WOULD LIKE TO USE THE DATA FROM HARDWARE PART USING A WIFI MODULE TO REPRESENT THAT DATA IN WEB PORTAL.HOW CAN WE DO IT.
