WigJig for Wire Jewelry
Intro: WigJig for Wire Jewelry
I will try to tell you how to make a simple jig for wire earrings or necklaces. I started to make earrings only with pliers but I soon realized that the more complex ones were not similar enough to call them "a pair". Then I discovered the wigJigs on http://beadstore.wigjig.com and I wanted to order, but then I thought I can save the time and money by making my own.
Materials you need (what I used):
- some pieces of harder wood (I found some already-cut rests at Baumaxx -for free, made out of some sort of very dense glued carton, almost like wood). For the 4 different jigs that I present here you will need 4 pieces of 15x15cm, or 2 pieces if you find thick enough material (>=1.8cm).
- 3mm thick iron pegs - furniture door stoppers (i found a 20pcs pack for ~3Euro/ ~4$) or anything similar (1-2cm long nails are also an option)
TIP1: don't use very thin wood since the pegs will come out on the other side and once on the table they will pop out.
TIP2: don't use soft wood (like conifers) as you won't be able to drill nice holes and the holes will bend due to the force applied to the pegs.
Tools you need:
- printer + paper
- pencil + copy paper (or some other way to transfer the pattern to the pieces of wood)
- Dremel + stander
- 3mm wood drill
Tools you need:
- printer + paper
- Dremel + stander
- 3mm wood drill
STEP 1: Transfer the Patterns on the Wood
Download and transfer the attached patterns on the pieces of wood as precisely as possible. If you mark only a dot in every center of the circles it would better when you use the Dremel.
I suggest you use the circle-shaped patterns for a start, since you can make some nicer designs (in my opinion).
STEP 2: Drill the Holes
Even if "doable" , it takes quite an effort to drill so many holes without a stander.
Measure the length of the pins you have found/bought and then set the drilling depth to that length+1mm.
Start drilling the holes. It will take you some 5-10 minutes. Then use a fine sandpaper to smooth the edges.
STEP 3: Add the Pegs
Now that you have the holes, you can add the pegs in whatever pattern you will like.
I use 1mm thick / 18 gauge wire but you can also use thicker wire without spacing the holes differently.
http://en.wikipedia.org/wiki/American_wire_gauge
Disadvantages vs a new one: you don't have too many peg diameter options. You can buy 3mm and 5mm for the 3mm holes, but hey! it's a start. You can also improvise or even buy a set of thicker pegs from the jig manufacturers.
I would be glad to receive suggestions about ways to use thicker pegs with the same holes, or even jewelry patterns. Thanks.
Enjoy making new jewelry, and don't forget to use some colored beads ;)
32 Comments
sumsmum 3 years ago
jamescorey 3 years ago
bajawoman2 3 years ago
The only reason I would make my own would be to use headless nails (instead of the pegs that always pop out) for the designs I use most. It would also mean that I’d only have to drill holes for the pegs I use per design.
Again, this is great, thank you!
Ejfaires 4 years ago
Sound View Counseling 4 years ago
Bongmaster 12 years ago
mesterila 11 years ago
@Bongmaster: As for showing it in use... I didn't have time lately to take pictures, but I guess cat76501 will come with some pictures soon ;)
@paqrat: you are right, I used metal tubing on top of the pegs to get different diameters. As for lining them in the board, it is a good idea if you work a lot with different patterns. What I ended up doing was using 4 patterns on different areas of the circular jig - with little variation.
delila7310 8 years ago
Can a regular peg board be used. Already has holes. You could draw your own pattern for it.
Flower1958 5 years ago
DorrieH 9 years ago
My dad made the Centaur jig for me using your pattern. Instead of wood he used two 9mm clear plexiglass plates, screwed together, which had the advantage of being clear enabling me to place a pattern under it. Thank you very much for this tutorial. It's fantastic.
tanyam1025 6 years ago
awesome idea
mesterila 9 years ago
RDeUslar 8 years ago
Great instructable and pattern, thank you :) Another good option to transfer the pattern into the wood would be taking it to a lasser cutter or engraver shop, and you can choose your kind of wood and thickness they usually have MDA which also works and if you want more thickness you can stack them. For thicker pegs you can do some with epoxy clay (the one you get on the grocery store that comes in 2 bars that you mix together), and pvc pipes, cut them to lenght you want fill with the clay and stick the peg in the center, let it cure and they are ready to go!
diana2872 8 years ago
Thank you, very useful!
elly.luiten.3 8 years ago
Dank je wel.
Grandioos,nu kan ik het ook zelf maken.
tracy.paglione.7 9 years ago
Could you do one for Delphi also please.
Kalpi 9 years ago
Hi .. This tutorial on making your own WigJig is awesome ....thanks a ton. I was searching high and low for this Jig in India but unfortunately there is no such thing here. I even thought I would import one for myself from the US but the shipping costs were two to three times the cost of the Jig itself. Your website came as a blessing to me :) I will now make one myself thanks to your tutorial. Please let me know whether I can transfer the pattern as it is on to a board or should it be enlarged ? Your reply would be highly appreciated.
