Wii Remote As Lightgun With Iron Sight / Line of Sight Accuracy on Windows Pc - 4 IR LED Tracking System - Geekonarium.de
Intro: Wii Remote As Lightgun With Iron Sight / Line of Sight Accuracy on Windows Pc - 4 IR LED Tracking System - Geekonarium.de
Use the 4 LED Tracker of Lichtknarre-tool with your Wii-remote to control your PC with the accuracy of iron sight / line of sight. The cursor is located where you aim.
The accuracy and the speed of the mouse got better while filming this movie :D
Features:
- Only needs to be calibrated once in theory.
- The user can move to a certain degree. It is not necessary to stand exactly in the spot where the calibration was made.
- Wii controllers can be quickly connected without the need for Windows menus.
- Easy to use with other games through vjoy2- or mouse-plugin.
- Yes you can rotate the Wii controller. It takes about 1 second for the programme to readjust. But this is actually no problem in use.
- The gun only needs to be 1.3 - 1.5 times as far away as the display is wide.
- Play Multiplayer with vjoy2!
Info for Tutorial
Sometimes you see different versions of the tool in the screenshot. Right top you see the version.
STEP 1: Buy Usb Bluetooth Radio
Make sure Bluetooth radio is compatible with wii remote.
You can check here: http://wiibrew.org/wiki/List_of_Working_Bluetooth_...
I use "TP-Link UB400 Nano USB Bluetooth 4.0".
Make sure the radio is plugged in.
STEP 2: Build 4 Infrared LEDs
Since version 0.9.8 you can use the BAD-LED mode for low powered IR-LEDs also. This steals an almost not noticeable/configurable amount of frames for interpolation.
For my take on building the infrared LEDs look here or watch the video:
https://geekonarium.de/en/lightgun-lichtknarre-led...
For small size screen it also works with low powered IR-LEDs. But if you want to be professional and play on beamer etc than go for my solution ;-). But there are far much more easy solutions on youtube with for example USB+LEDs. But beware you need Infrared LEDs.
See also
If you don't want to build 4 LEDs and use that tool right away with some disadvantages than look no further than here: https://www.instructables.com/Wii-Remote-As-Lightgun-With-Iron-Sight-Line-of-Sig/
STEP 3: Installation
Download the software and Install:
STEP 4: Activate 4 IR LED Tracker Plugin
Activate the 4 IR LED Tracker if this has not already been done. There will be many more trackers in the future, but this one is for wii and 4 Infrared LEDs.
More technical infos about plug-in system: https://geekonarium.de/en/lightgun-lichtknarre-abo...
STEP 5: First Calibration: Mount Infrared LEDs to Your Display(Beamer, Display, Etc)
Click on the button "LED-Calibration". After that the screen of the second picture should appear, which tells you where to place your LEDs. There where the lines meet the edge.
I mounted all with magnets for example. The LEDs from the picture is the old LED model. Updated one is under the link in Step2. The new model is much more tiny and more easy to build.
Make sure that you mount the LEDs vertically in a ratio of 74 to 26 and horizontally in a ratio of 50 to 50.
If you have a distance between the LEDs and the screen, then you should ignore the instructions from the calibration screen and measure the ratios yourself.
STEP 6: Connect Wii Remotes
Hold 1 and 2 until the Wiis are listed in the application. It is not necessary to use windows tools to connect. It may take up to 18 seconds for the Wii to be listed. However, it is better than using the Windows tools to configure.
You can connect at least 4 Wii-remotes by holding 1 and 2.
All Wii remotes that have been connected will be assigned to a player. The application remembers which device was assigned to which player if you want it to.
STEP 7: Calibrate the Gun
Click on the button "set/override all gun-calibration". After that the black screen should appear from the screen. Try to place the dots in the boxes. They should be as close to the edge of the screen as possible.
This will defined the default calibration for all new connecting wii remotes. Atm it is not possible to calibrate each wii remote individual.
STEP 8: IR-Offset Calibration
Sometimes the app user may not be able to build the IR LEDs directly to the screen. Since the app only sees the LEDs, it thinks that the screen is larger than it really is. This is where the LED offset calibration comes into play.
You can set the values individually for all LEDs. Top, bottom, left and right. (Look Screenshot)
To do this, start the LED Offset Wizard or calculate the values yourself.
As you can see in the screen, there are two types of offsets, the LED offset and the game offset. Here we are only talking about the LED offset.
To calculate the values, take a look at the following tutorial:
STEP 9: Adjust Connector Plugins for Gaming.
You can use the default "Mouse"-Connetorplugin to controll the mouse with the first wii remote or you can goto http://vjoystick.sourceforge.net/site/index.php/81... install and configure and use the vjoy-Plugin to bring the input of the wii remotes as an controller input to other programms. Then you will be able to use multiple wII remotes in the games.
Yes multiplayer is possible with vjoy2 plugin. Play with more than 2 player.
Here a detail tutorial how to configure the emulators: https://geekonarium.de/en/lightgun-emulator-config...
If you want to programm your own plugin watch no further than here:
https://github.com/Geekonarium/LichtknarrePlugin
Dolphins love vjoy :D
More infos about Lichtknarre plug-in system: https://geekonarium.de/en/lightgun-lichtknarre-abo...
STEP 10: Lenses
More infos about lenses comming soon.
STEP 11: Enjoy
Happy playing!
the gun should be 1.3 to 1.5 times as far away as the screen is wide. Otherwise the detection won’t work perfectly. But its very near by!
STEP 12: Troubleshooting
More Infos about troubleshooting look here: https://geekonarium.de/en/lichtknarre-lightgun-wii-4-led-tracker-plugin/#troubleshooting
STEP 13: This Is Not the End!
Checkout what is comming soon:
STEP 14: Updates
Actual download:
https://geekonarium.de/en/lichtknarre-lightgun/
Please look here for changelog:
https://geekonarium.de/en/download-changelog-light...
And all existing versions:
STEP 15: More Infos :D
STEP 16: IR LED Bar Hack :D
My Friend PolloLocco77 from the comments posted a cool hack which i want to share here so you don't miss it. For some it makes live more easy!
Look at the image.
He bought 4 x USB IR bars. He covered one LED at a time with insulating tape and positioned the active LEDs with the Lichtknarre calibration tool. So he uses only one LED from each IR Bar.
STEP 17: MARK As Made
Please do me a favor an mark this project as made if you use it :)
16 Comments
StumpChunkman 3 years ago
Fusselkroete 3 months ago
Big thanks :)
StumpChunkman 3 months ago
Send an email to support@instructables.com. Link them to this project, and let them know about the spacing issues. Someone there should reach back out to you shortly.
Why is the html so buggy now? Spaces are huuuge :O Can you fix this? This appeared from nothing.
Fusselkroete 2 years ago
StumpChunkman 2 years ago
Fusselkroete 3 years ago
But still lot of work has to be done. Plugins needs more options for rumble etc. Multiscreen support etc :D
顾剑 10 months ago
Fusselkroete 10 months ago
您好,很抱歉,我们很难支持所有第三方wiimote设备。购买它们都是反向工程。我也不是逆向工程专家。也许将来我会找到一个支持所有这些设备的库,我会把它放在我的后脑勺。感谢您的积极反馈!
deepl.com helped me to translate ;D
sonic3233 1 year ago
Wiimote works fantastic with this program.
Probably the cheapest and most accurate solution is to use a gun for playing games on PC.
I want to ask: Do you plan to use off-screen charging?
For example, when you point your weapon off-screen, does the A button automatically press?
It could be an optional feature and with this the weapon would become perfect.
Fusselkroete 1 year ago
Yes this feature is on the todolist.
I can't tell you exactly when the feature will be released because I don't want to commit to dates, but I hope soon.
here the todolist: https://geekonarium.de/en/download-changelog-lightgun-lichtknarre-wiimote-line-of-sight-pc-windows/#commingsoon
If you want todo me a favor: Can you mark this project as made? :>
And it works great.
Only minimal costs are used for the production of this weapon.
Accuracy is the same as (Ir4gun or sinden).
Thank you for this program.
Before I found out that this program existed, I was using a program (GlovePIE) and modified the off-screen loading script as follows:
// Mouse Buttons
mouse.LeftButton = Wiimote.B
mouse.RightButton = wiimote.PointerVisible = 0
mouse.MiddleButton = Wiimote.One
I dont have the comparison between sinden and IR4gun but i heard it has less latency.
https://geekonarium.de/en/lightgun-emulator-configuration/
Updates:
- Now with IR-Offset calibration to make it more accurate.
- Better position calculation
- Setup installs all needed runtimes now.
