Wire Crochet Interlaced Bead Bracelet
103
Introduction: Wire Crochet Interlaced Bead Bracelet
I wanted to make a bracelet with a lot of beads, but not a bead loom bracelet. I wanted the bracelet to be voluminous, interlaced, unique. I can crochet, so I came up with the idea of crocheting this bracelet from parts - rings, and then connect these rings, intertwining them. I really like the result. I crocheted with wire and beads and I didn't spend a lot of time creating this bracelet. No one has ever made such a bracelet, so this bracelet is definitely unique.
Step 1: Gathering the Necessary Material and Tools
You need:
wire 0.1 mm,
seed beads,
7-8 beads with a diameter of 8 mm,The quantity depends on the length of the bracelet
a clasp hook,
a clasp circle,
crochet hook 1.5 mm,
scissors.
Step 2: Stringing
String a lot of seed beads onto the wire.
Step 3: Crocheting Rings
Slip knot, * slide in one seed bead, 1 chain stitch. Repeat from * 29 times.
Slip stitch to form a ring.
1st round: slide in one seed bead, 1 chain stitch. Crochet it in every stitch.
2nd round: slide in one seed bead, 1 chain stitch. Crochet it in every stitch.
Finish of crochet. Cut wire.
Step 4: More Rings
Crochet 6-8 beaded rings. The number of rings depends on the length of the bracelet.
Step 5: Connecting the Rings
Connect the rings as in the photos.
Step 6: Final Ring
Crochet a chain of 15 beads. Fold the large ring and thread the crocheted chain through it. Slip stitch to form ring.
Crochet two rounds like in the step 3.
Step 7: Adding Clasp Circle
Fold the wire several times and tie to a clasp circle. Then tie it to the extreme crocheted beaded ring. Twist the ends of wires.
Step 8: Adding Beads
* String a mother-of-pearl bead. Then wrap the wire around next crocheted beaded ring. Thread 7 seed beads and wrap the wire around next crocheted beaded ring. Repeat from * until you wrap the wire around the opposite end of the bracelet.
Step 9: Adding Clasp Hook
Wrap the wire around the clasp hook several times and tie it. Cut the wire and hide the end.
Fashion Challenge
Fashion Challenge
Be the First to Share
    • Organization Contest
    • Halloween Contest
      Halloween Contest
    • Micro:bit Contest
      Micro:bit Contest
