Wire Scorpion
Intro: Wire Scorpion
Some time ago I saw a wire scorpion for sale in a souvenier shop. Fascinated, I bought one, determined to figure out how to build my own. Many trials and errors later, I figured it out. I'm not sure this is exactly how the "proffesional" one was made, and there is a bit of room for improvement, but this is definately a guide to get started.
Materials needed:
Soft wire (20g from WalMart's craft section in this case)
Wire snips
Pliers (to aid shaping)
Now, lets go through my first instructable.
Materials needed:
Wire snips
STEP 1: Gather Wire and Build Tail-
If using 20g wire, cut 14 pieces of wire 7inches(17cm) long. If using thicker wire, allow a little more length. (less for thinner wire)
Gather 6 pieces of wire together, find the middle, and wrap 1 strand around the rest. Repeat until two wires are left uncoiled. Twist these to the end.
To twist wire, bend wires to make a 90 degree angle, place between thumb and finger, and twist, making sure to keep wire at 90 degree angle.
STEP 2: Adding Legs-
Bend the remaining 8 pieces of wire in half, these will be your scorpion's legs. Begining at the end of the coil (middle of the bundle), wrap the end of a bent wire around the bundle (see picture to clarify), and pull tight. Repeat for all 8 wires. Be sure each wire crosses in the same order (ie: left over right or vice versa).
STEP 3: Build Body-
Flip scorpion over, and... How to explain...? Take the furthest 'back' pair of wires, and wrap them 'forward' over eachother (make sure the are each in the same order again), and then around the bundle again (see pictures to clarify). Repeat 7 times.
STEP 4: Building Legs-
Flip scorpion over again, and twist together pairs of legs.
STEP 5: Building Mandibles and 'arms'-
Take remaining 6 wires, and seperate into 3 pairs. The bottom most pair, top left most pair, and top right most pair.
Twist the top right pair together, and the top left pair as well.
STEP 6: Trim and Bend-
Cut legs, tail, arms, and mandibles to appropriate lengths, and bend into desired pose. If you want, take the suggestion of another Instructable I saw, and dip it in PlastiDip for a bendy toy scorpion.
Enjoy!
Enjoy!
84 Comments
ChrisR511 5 years ago
Chelc-A 7 years ago
sengrath 9 years ago
HI I started building this , but stuck on step 3, which furthest back wires ? i have now 6 loose ends in the front for mandibles and arms , and 8 ends on each sides for the legs..right?.
BlueS3 9 years ago
YAY! But the wire twist is kind of one around the other. To twist both around each other, push each wire in a half twist. So push the right wire around to the left, then the new right wire back to the left; looks better.
spylock 11 years ago
aleluky 13 years ago
taria 12 years ago
rednivarpuff 13 years ago
garyflann 14 years ago
Mirage_662 14 years ago
laccerbero 14 years ago
superhubbardman 14 years ago
dragonsniper 14 years ago
Dr. Tarantula 14 years ago
jdogsbart 14 years ago
ward2u 14 years ago
Wonderful,
Wonderful
thanksssssssssssssssssssssssssssss'
ruckerr 15 years ago
bowmaster 15 years ago
weloveclover 15 years ago
jacobzman 15 years ago
