Wire Tree Sculpture
215,074
153
27
Introduction: Wire Tree Sculpture
This will show you how to make a beautiful work of art in less than an hour. Almost free to make, this is a great gift idea, or make one for your self.
Step 1: What You Will Need
All of these Items are either really cheap, or FREE!!!
Wire (I used steel wire I found the other day, but any bare wire works)
Needlenose Pliers
Optional Items
Base to mount on (I used a rock)
Gloves (recommended on heavier guage wire)
Decorations (and adhesive of some kind if needed)
Step 2: Cut the Wire
You want your wire to be at least 8 inches long, that way you have room to twist and bend later. I did it about 14 inches long, I wanted a larger tree.
Step 3: Keep Cutting!
You will need quite a few pieces of wire. It's actualy a good thing if they are varying in length a little. Just eyeball it as you go, using a previous piece as a judge in length. You're not going for perfection here, I think that's part of why this is so fun.
Step 4: Group and Start to Form
Well, I'm out of wire, so I guess I'm done... I got 21 pieces cut from that ball, not bad. For thicker wire, gloves gome in handy for this. grab the wire up in a bunch and literally twist the center a few times. You will get an uneven spiral. This will be the trunk of the tree.
Step 5: Forming the Branches
after you have the tree twisted in the center. start splitting up the wires. it's easiest to split into 2 large branches but you can literally do it however you want to. Take your groupings of wire and twist them in a similar fashion to what you did for the trunk.
Step 6: Keep Splitting and Twisting
Just like you did on the main branches, split up the wires and twist those groupings. As the groups get smaller, you will start to see a bare tree form emerge. Split and twist until You have single wire branches in the different directions. Bend your branches in different directions to fill out the desired shape.
Step 7: Got the Top Half, Now What?
Now it's time to shape the roots. Not much to it, just apply the same method from the top to the bottom half. Flatten out your roots with your hands or your pliers. At this point, your tree is done. All that is left is a little customization.
Step 8: Presentation
For this specific tree, I used a flat bottomed rock (I think it's granite) from the courtyard of my apartment. All I did was set the tree on the rock, took my pliers and bent the roots around it. I curled them on the bottom so the tree wouldnt scratch whatever furiture it ends up on. I've also used flower pots with sand, bonsai stands, it doesn't really matter. Pick something that you ant to use and go with it.
Step 9: Finishing Touches
This tree still felt like it needed something else. I happened to Have a red piece of foil paper from a pack of cigarettes my friend left at my place, so I quickly folded an origami crane and glued it to a branch. You can decorate it however you like. Some Ideas are beads, buttons, soda tabs, even hang your jewelry on it. There you have it. A Metal sculptre that is all your own. Snazzy.
5 People Made This Project!
  • Meatless Challenge
    Meatless Challenge
  • Remote Control Contest
  • Backyard Contest
    Backyard Contest
27 Comments
soullight
soullight
13 years ago on Introduction
I am new to this hoby and was wondering if any one knows where I can buy 1mm un-holed gem chips.
PrabalS
PrabalS
6 years ago
http://www.amazon.in/Trees-Jute-Twines-Prabal-Sharma-ebook/dp/B01E5XTHBK/ref=sr_1_1?s=digital-text&ie=UTF8&qid=1460537867&sr=1-1&keywords=model+train+trees
folklife
folklife
10 years ago on Step 9
I used scrap copper stranded wire- removed the rubber covering, and started twisting like you said. I also soldered some sections to hold in place. Fab idea!
poi_pai
poi_pai
Reply 11 years ago on Introduction
Especially if the copper goes green over time, that'd be gorgeous!
andi456
andi456
My grandpa made one of these, but he polished amethyst and glued it to the branches as leaves. It is very cool.
poi_pai
poi_pai
Reply 13 years ago on Introduction
That sounds gorgeous, I might have to try that, I have some citrine that would work.
poi_pai
poi_pai
I don't see why not, might be kinda cool with all the different colored ones!
shelbabyrn
shelbabyrn
What is the best gauge wire to use and any suggestions on where to find colored craft wire?
poi_pai
poi_pai
That'll work, like spray paint the finished piece?
poi_pai
poi_pai
I'd say jewelry supply stores, or craft shops, I've got a place called Hobby Lobby near me that sells a 22 gauge wire that works well for more intricate, the last wire I bought there in colors was forest green and blood orange red! Nifty stuff, but a little pricey.
KreaKatri
KreaKatri
Great instructable :) I think I'm gonna make it with wires with same widths, but different colors(Goldish, silverish and one that changes colors a bit like gasoline in water, only darker)
poi_pai
poi_pai
14 years ago on Introduction
Thanks for the feedback. I've done them with wire as thin as 22 guage, and you're right, you can get incredibly detailed. Those ones were copper on gold veined quartz, and sold quite well to offices around town. :)
chinasmom2000
chinasmom2000
poi_pai, this looks SO cool!! What a great instructable! I wonder if you could use different gauges of wire in the same tree to get more detail; smaller branches, twigs, etc. I love this and will try it; it looks great!
